Connecting two powerlink sources to Beolab speakers. Is it possible?
This post has 3 Replies | 0 Followers
Sweden
Posts 357
Silver Member
Martin Posted: Thu, Feb 26 2015 11:49 AM
I hope someone know if it is possible to connect two Powerlink-sources to beolab-speakers?
I want to connect one Beosound 9000 and one Beosound 5/Beomaster 5 to a pair of Beolab 5 with powerlink-cables.
Will the soundquality remain the same as if one source was connected? Will it work?
Regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
leosgonewild
Helsinki, Finland
Posts 2,373
Can´t you connect them with masterlink, and set the BS9000 as a slave?
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Feb 26 2015 12:30 PM
There is a Thing called almando powerlink Switch.
No experiences with it, but I have heard some positve comments on this Forum about it.
Ralf
Sweden
Posts 357
Silver Member
Martin replied on Thu, Feb 26 2015 12:54 PM
Hi Guys,
Thanks for your answers. Yes I can connect with masterlink, but I want to know if it is possible to connect with Powerlink directly into the speakers. I hope someone knows.
/Martin
Page 1 of 1 (4 items) | RSS
