How do I connect a master control link 82 to my older 5000 system
This post has 22 Replies | 1 Follower
pierre5000
California
Posts 10
pierre5000 Posted: Thu, Mar 5 2015 2:31 AM
I purchased on eBay master control link cable a master control link 82 connector box with the following imputs transceiver speakers and a link 1 and link 2 imputs. What kind of connectors go to link1 and link 2, and does it go directly to the receiver with the 8 wire master control link cable
elephant
AU
Posts 8,219
I'll photograph some pages from my manual for you
BeoNut since '75
pierre5000
California
Posts 10
I'll be looking for it thank you so much
elephant
AU
Posts 8,219
pierre5000:
Here you go - for your benefit - and les autres in the future.
BeoNut since '75
elephant
AU
Posts 8,219
Sorry about the orientations.
Let me know if any of the orientations, cropping or focus is an issue for you.
There are a series of system layout drawings but I chose this one as it is the simplest and probably matches your planned usage:
BeoNut since '75
elephant
AU
Posts 8,219
Wiring details with instructions to follow
BeoNut since '75
elephant
AU
Posts 8,219
Here are instructions for the system solution diagrammed. There are three other combinations in more sophistication (multiple rooms in daisy chain, or star fish layouts) with diagrams and instructions that I can snap and post on request.
BeoNut since '75
elephant
AU
Posts 8,219
These instructions are for the simple solution diagram.
If you want multiple rooms in daisy chain or star fish layouts please ask !
BeoNut since '75
elephant
AU
Posts 8,219
pierre5000:
BeoNut since '75
elephant
AU
Posts 8,219
Sorry for the double post of the 4 pages of instructions - the first attempt generated an error message and appeared not to work. But then appeared after I did the second (re)post. Go figureSad
And now there is triple post Unsure
BeoNut since '75
pierre5000
California
Posts 10
Thank you for taking the time to send this information.
My link is to only one other room so pretty simple I hope
Just need to read instructions.
Curious though what type of connector do  I use to hook up to my receiver ( 5000 ) ?
elephant
AU
Posts 8,219
elephant replied on Thu, Mar 5 2015 11:03 PM
pierre5000:
Let me double check
However from memory there was a cable that goes into the box for which you have the instructions, and the other end has two the B&O standard speaker plugs - left and right.
You will have to wait some 12 to 24 hours before I am back at my "museum" Smile
BeoNut since '75
pierre5000
California
Posts 10
Thanks again will check again in 24hrs about conformation about standard B&O speaker connectors
elephant
AU
Posts 8,219
This is a list of part numbers for the different lengths of cable
Not really "optional" !
BeoNut since '75
elephant
AU
Posts 8,219
And I have been looking for my real life cable ... But it's not in the box of new transceiver (hence "optional") nor is it my old transceiver's box of odds and ends from when dismantled the MCL to put in ML - sorry Sad
BeoNut since '75
pierre5000
California
Posts 10
Thank you
if you say it is the standard speaker connections then I'll check my extra parts box to see if I have some
When it says 3 pin speaker connectors I take it means it is the connection points of the wires and not the actual pins that go into the speaker imputs on the beomaster receiver which is 1 large flat and 1 small pin like
elephant
AU
Posts 8,219
pierre5000:
I think it may have to be 3 pin.
Let's check the wiring at the other end.
After all the transceiver has to send signals through the MCL to the BeoMaster.
I will check the speaker 2 ports on my 5000 to see if there is a plug hole for the third pin.
BeoNut since '75
elephant
AU
Posts 8,219
pierre5000:
Hi again. I think this BeoMaster 5000 manual page identifying the two SP-eaker inputs, and the two photos show that SP 2 does have a third pin that I am sure is used as a data signal from the transceiver. (In typical B&O manual fashion the diagram is back to front from the actual equipment) ...
BeoNut since '75
elephant
AU
Posts 8,219
pierre5000:
Also this wiring diagram shows that the White and Pink leads inside the MCL cable are used by the 3rd speaker pin.
BeoNut since '75
pierre5000
California
Posts 10
This all makes sense now it would have taken much longer to figure this out on my own. Now I just need to find a pair of these 3 pin plugs. Thank you again for all the help.
elephant
AU
Posts 8,219
elephant replied on Sat, Mar 7 2015 10:49 AM
pierre5000:
No problem !
Best if you can source the appropriate length of cable from a dealer.
You might make it up yourself - however please make note of the shielding !
And maybe Lee (Beoworld) OR Steve (SoundsHeavenly) may be able source / supply you with the cable or equivalent.
Good luck !
BeoNut since '75
bigphil
Posts 69
Silver Member
bigphil replied on Fri, Mar 27 2015 5:01 PM
Hi I have a 1981 Beocenter 7000 and was wondering if this applies to my system?  The only cables going to the Beocenter are 2 speaker cables connected to the speaker 2 output.?  How does the remote control work from the other room I'm a bit confused. I'm  looking for one of these MCL units. Thanks Phil
elephant
AU
Posts 8,219
elephant replied on Sun, Mar 29 2015 7:30 AM
bigphil:
Hi PHIL - you may be in the pre-MCL era. May I suggest you check the www.beotech.org site and see what options are supported and then start a new thread? You may get a better response that way.
BeoNut since '75
Page 1 of 1 (23 items) | RSS
