I purchased on eBay master control link cable a master control link 82 connector box with the following imputs transceiver speakers and a link 1 and link 2 imputs. What kind of connectors go to link1 and link 2, and does it go directly to the receiver with the 8 wire master control link cable
BeoNut since '75
I'll be looking for it thank you so much
pierre5000:I'll be looking for it thank you so much
Thank you for taking the time to send this information.
My link is to only one other room so pretty simple I hope
Just need to read instructions.
Curious though what type of connector do I use to hook up to my receiver ( 5000 ) ?
pierre5000:Thank you for taking the time to send this information. My link is to only one other room so pretty simple I hope Just need to read instructions. Curious though what type of connector do I use to hook up to my receiver ( 5000 ) ?
Thanks again will check again in 24hrs about conformation about standard B&O speaker connectors
Thank you
if you say it is the standard speaker connections then I'll check my extra parts box to see if I have some
When it says 3 pin speaker connectors I take it means it is the connection points of the wires and not the actual pins that go into the speaker imputs on the beomaster receiver which is 1 large flat and 1 small pin like
pierre5000: When it says 3 pin speaker connectors I take it means it is the connection points of the wires and not the actual pins that go into the speaker imputs on the beomaster receiver which is 1 large flat and 1 small pin like
pierre5000:When it says 3 pin speaker connectors
This all makes sense now it would have taken much longer to figure this out on my own. Now I just need to find a pair of these 3 pin plugs. Thank you again for all the help.
pierre5000:This all makes sense now it would have taken much longer to figure this out on my own. Now I just need to find a pair of these 3 pin plugs. Thank you again for all the help.
Hi I have a 1981 Beocenter 7000 and was wondering if this applies to my system? The only cables going to the Beocenter are 2 speaker cables connected to the speaker 2 output.? How does the remote control work from the other room I'm a bit confused. I'm looking for one of these MCL units. Thanks Phil
bigphil:Hi I have a 1981 Beocenter 7000 and was wondering if this applies to my system? The only cables going to the Beocenter are 2 speaker cables connected to the speaker 2 output.? How does the remote control work from the other room I'm a bit confused. I'm looking for one of these MCL units. Thanks Phil
