Beogram 8002 DIN Input board
Adriano
Lancaster, PA
Posts 5
Adriano Posted: Fri, Mar 6 2015 11:13 PM
Hello BeoWorld,
somebody tried to repair an 8002 and decided to remove all the wiring from the DIN input board..
I am wondering if any of you guys has a photo of the board so that I can re-build the connection..
Thank for your help !
Adriano
sonavor
Texas, United States
Posts 3,732
Hi Adriano,
Your image didn't post correctly. Are you referring to this Beogram 8000 DIN board?
sonavor
Posts 3,732
Sorry, I mis-read your post.  You are looking for the Beogram 8002.  The BG 8000 is similar but here are some pictures of the Beogram 8002 DIN board and wiring.
sonavor
Posts 3,732
Here is a picture of the board
sonavor
Posts 3,732
Adriano
Lancaster, PA
Posts 5
What can I say... You saved my life :) lol
Thank you very much !!!!!!
I am doing a last check before plug the turnt
Adriano
Lancaster, PA
Posts 5
And I have noticed that the power cord was also misplaced... I did open the power supply cover and found the fuse BUT.. something doesn't look right .. I see a loose condenser and some connections that do not make a lot of sense.. it is evident that the previous person did remove the power cord ( did not put that back properly ) and at this point I don't trust anything anymore..
Sorry about this, but do you happen to have a photo of the power supply / fuse area ??
sonavor
Posts 3,732
Here is a picture of one of mine.
Adriano
Lancaster, PA
Posts 5
Adriano replied on Tue, Mar 10 2015 10:40 PM
Thank YOU , again.. problem solved :)
Page 1 of 1 (9 items) | RSS
