Hello BeoWorld,
somebody tried to repair an 8002 and decided to remove all the wiring from the DIN input board..
I am wondering if any of you guys has a photo of the board so that I can re-build the connection..
Thank for your help !
Adriano
Hi Adriano,
Your image didn't post correctly. Are you referring to this Beogram 8000 DIN board?
Sorry, I mis-read your post. You are looking for the Beogram 8002. The BG 8000 is similar but here are some pictures of the Beogram 8002 DIN board and wiring.
Here is a picture of the board
Here is another one.
What can I say... You saved my life :) lol
Thank you very much !!!!!!
I am doing a last check before plug the turnt
And I have noticed that the power cord was also misplaced... I did open the power supply cover and found the fuse BUT.. something doesn't look right .. I see a loose condenser and some connections that do not make a lot of sense.. it is evident that the previous person did remove the power cord ( did not put that back properly ) and at this point I don't trust anything anymore..
Sorry about this, but do you happen to have a photo of the power supply / fuse area ??
Here is a picture of one of mine.
Thank YOU , again.. problem solved :)
