Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
@ Hiort
Thank you for your report.
I will be afraid to scratch this portable wood jukebox.
A rubber black or white version will be more affordable either.
For me € 1.700 will be a correct price for a BeoSound Moment.
We have to wait for a Moment Mk II without software problems and a screen in higher definition.
Well, I don't need that iPad app for changing music, I do it perfectly from the Moment. But I enjoy the iPad app in the kitchen, it gives me such a nice big cover picture of whats actually playing.
Chris, give your wife the surrounds and meanwhile take the Moment home, all in one trip
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Ok, you got me. i'm speechless
lonfred:Does it work fine from the bl3500 and bl2000? Kan you change track and playlist with your BEO4?
You can use it from Bl3500 also today. I do listen to radio, my music and pattern play thru my bl3500, using my beo4
Normann:You can use it from Bl3500 also today. I do listen to radio, my music and pattern play thru my bl3500, using my beo4
Yes.
Today i have connected it thru a delay box (not operative yet) and to a ML/NL converter.
In the ML/NL converter you can either set it up as A-master or Av-master. I set it up as AV- master and then everything works just fine!
The only thing that is not working (as for now) is the volume controll on the Jukebox on the Moment, and when you switch from example radio to TV, it doesn't shut down.
in A master setup, everything works, except when you starts music, radio in a linkroom the master in the room where the Moment is connected starts playing. These things will get a fix in the updated software in May.
And if you have NL and ML product you can just use one of them, and not both as for now.
I am using the Moment just as my BS5/BM5 setup i had earlier
Normann: Yes. Today i have connected it thru a delay box (not operative yet) and to a ML/NL converter. In the ML/NL converter you can either set it up as A-master or Av-master. I set it up as AV- master and then everything works just fine! The only thing that is not working (as for now) is the volume controll on the Jukebox on the Moment, and when you switch from example radio to TV, it doesn't shut down. in A master setup, everything works, except when you starts music, radio in a linkroom the master in the room where the Moment is connected starts playing. These things will get a fix in the updated software in May. And if you have NL and ML product you can just use one of them, and not both as for now. I am using the Moment just as my BS5/BM5 setup i had earlier
Thanks.
When you say that you have connected Moment to the NL/ML, does that mean that you have connected Line out on Moment to Line in on the NL/ML converter?
This is how my system is setup:
I guess the difference is, that Normann has set his Moment to use the NL/ML Converter, and you have set it to use the BV!
Am I right?
It can't work in both situations by now - the update(s) in May will change that.
Probably,
I´m just curious how he has connected Moment to the NL/ML Converter.
Hallo,
the Netlink seems to based on TCP/IP connection. You have to use a normal network switch for the connection. One cable for the Moment and one for the NL/ML gateway. I was in the same situation first I wondered if this can be true. But it seems to be netlink over TCP/IP.
Frank
frank2u: Hallo, the Netlink seems to based on TCP/IP connection. You have to use a normal network switch for the connection. One cable for the Moment and one for the NL/ML gateway. I was in the same situation first I wondered if this can be true. But it seems to be netlink over TCP/IP. Frank
I guess thats the way I have it setup. See my drawing in my earlier post in this thread.
BeoBoy68: We have to wait for a Moment Mk II without software problems and a screen in higher definition.
I doubt there will be a MkII, since the software will be updated continuously.
Regarding screen resolution, do you think it actually looks bad or is it that you think its a bad specification? Just curious.
This is right MM.
To my line in on the ML/NL i have connected a Playmaker
Normann:This is right MM. To my line in on the ML/NL i have connected a Playmaker
Hiort:I doubt there will be a MkII, since the software will be updated continuously.
Hiort: Regarding screen resolution, do you think it actually looks bad or is it that you think its a bad specification?
It's not connected with any cable, just over the wifi. If i can remember correctly..
Hiort:I doubt there will be a MkII, since the software will be updated continuously. Regarding screen resolution, do you think it actually looks bad or is it that you think its a bad specification? Just curions.
The BS Essence is not NL.
The 2nd Generation of it is NL - that is the reason for the 'new version'.
This does not apply to the BS Moment.
Does your iPad/BeoMusic app turn on the BV respectively the BeoLabs, when you start using it
Chris Townsend:The resolution of the screen although not up to the latest iPad standards, wouldn't really bother me. The fact that I can use my iPad Air all day and not notice a finger smudge, which I couldn't say the same for the Moments tablet. Then there's the huge elephant in the room, the Moment doesn't support the excellent Beomusic App, but my iPad does. What madness.
Millemissen:Does your iPad/BeoMusic app turn on the BV respectively the BeoLabs, when you start using it MM There is a tv - and there is a BV.
StUrrock:What Madness, What Tueness.
Chris Townsend: But what's the point of turning it on, if I can't then search for genres/decades/artists etc on Deezer?
This is a good point. I hope this is on the update list for the next version as well.
Chris Townsend: Then there's the huge elephant in the room, the Moment doesn't support the excellent Beomusic App, but my iPad does. What madness.
Aha!
You simply want that the BeoMusic app should be the interface on the Jukebox, or?
It's simple enough, the Moment tablet should run a combination of the BeoApp and the Moment software - it should be fully featured and complete. The App should be some subset of this - it shouldn't be offering features not found on your £1700 device (supposedly designed from the ground up for this purpose)!!
As Chris says, this is madness and needs addressing pronto!
Ban boring signatures!
Today I’m having the Moment also a month. A short thought.
It is exactly what I was searching for to replace my Mac Mini iTunes with Amarra and Audirvana combo.
I now trowed that awfully iTunes completely out of the house. From the beginning, it was always been the syncing that drives me a little crazy. I think of the stuff on iTunes media as my stuff. I’d like to control it. Last year in Cupertino, there’s was a guy with an untucked shirt muttering, “But I thought people liked U2… No, dropping a U2 “gift album” into my iTunes account was over the top with me.
There are off course things that can be bettered as is the search function, a two letter search would be good enough for me with my large library. But viewed in the whole the Moment gives me now that perfect control of my music library and adds simplicity of operation for the whole family. Just waiting for that multiroom and I can say, well done B&O!
