One month with the Moment
This post has 863 Replies | 16 Followers
Hiort
Sweden
Posts 2,895
Hiort Posted: Sun, Mar 8 2015 3:13 PM
I was thinking of writing a few lines after having Beosound Moment in my home for about a month now.
I will not focus on the flaws in the software that we have been writing about in various threads, since they will most likely be fixed over time.
I would rather give a view of how Beosound Moment has worked in my everyday life, hoping that it would benefit other readers of this forum if they consider Beosound Moment.
Here we go:
First some background.
Moment replaced my Masterlink Audiomaster (Beocenter 2). Since I did not have any other Masterlink Audio/video master, I had nothing to provide current to the Masterlink. I had to overcome that problem by adding a second life Beolink Converter Type No 1611. B&O will release a "black box" solving the same problem within short.
Why did I get Moment in the first place?
Main reason was that I had all my CDs ripped and imported into iTunes, so I did not need a CD player anymore and the way to play those CDs was cumbersome. (Activate A.AUX. Get iDevice. Start Apple Remote. Connect to Airplay (Playmaker). Play. Use phone to skip track and remote to e.g. adjust volume). Same thing with playing from music service. I also had problems with dropouts.
So how is Moment used in everyday life?
Well, in the mornings, while eating breakfast before work, I just press "PatternPlay" (push the round area on the wodden side) and it knows what radiochannel I always listen to at that time in the day.
While commuting to and from work I listen to the Deezer app and let it provide me with my favorites and some music in the same style by using the "Flow" function. That way I have discovered a lot of (to me) new music that I have added as "Loved tracks"
When at home again in the evening, I can easily pick those tracks again, by getting into my Loved Tracks playlist, using the Jukebox.
When preparing dinner together with my wife, after work on Fridays, we usually listen to some more relaxed music that goes nicely with a dry martini or a glass of read wine.
I usually flip over to the "displayside" of the jukebox and just press the middle circle in the green area of the Mood Wheel, and Moment serves us the music we would expect.
If not, I press the remote and easily skip to next track.
I think Moment need more frequent use, to understand that I want to listen to that "green mood" music, every friday evening around 6 PM :)
If I want a specific album or track, I use the BeoPlayer app.
On weekends, if I am at home I'm more into the red area of the Mood Wheel. That gives more upbeat music that goes well with cleaning the house, playing with the dog, or whatever we do.
All in all, the Moment has given me a more casual way of listening to music. Sound quality is as good as I would expect. Tunein radio and Deezer sounds very good as well. There are areas for improvement with regards to features and functions, and I'm sure B&O will fix those in coming updates.
/C
Chris Townsend
Qatar
Posts 3,531
Does the Moment come with the Beomusic App?
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Mar 8 2015 3:22 PM
Well, not really. You download it for free.
lonfred
Posts 200
lonfred replied on Sun, Mar 8 2015 6:36 PM
Does it work fine from the bl3500 and bl2000? Kan you change track and playlist with your BEO4?
BeoBoy68
Alsace 🇨🇵
Posts 1,247
@ Hiort
Thank you for your report. Yes - thumbs up
I will be afraid to scratch this portable wood jukebox.
A rubber black or white version will be more affordable either.
For me € 1.700 will be a correct price for a BeoSound Moment. Big Smile
We have to wait for a Moment Mk II without software problems and a screen in higher definition. Yes - thumbs up
Chris Townsend
Qatar
Posts 3,531
If you could use the Beomusic App on the Moments pad, that would be a vast improvement. There's no way I'm spending £1,700 on a music system with a pad thingy, that then requires me to use my own psd thingy with the better software to operate it because it's own pad thingy can't. It's bonkers.
Have I got that wrong?
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Mar 8 2015 7:43 PM
Well, I don't need that iPad app for changing music, I do it perfectly from the Moment. But I enjoy the iPad app in the kitchen, it gives me such a nice big cover picture of whats actually playing.
Chris, give your wife the surrounds and meanwhile take the Moment home, all in one trip Big Smile
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Chris Townsend
Qatar
Posts 3,531
If it were her way, the bedroom would be an 11-55 with matching 12-3's and a 19 for good measure. I'd be happy with a Beolit and a pretty maid.
Life does not begin at forty[:\'(]
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Mar 8 2015 7:50 PM
Surprise Ok, you got me. i'm speechless
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Mar 8 2015 9:17 PM
lonfred:
No Masterlink integration yet. Will come in May.
I can change tracks but not playlists with beo4.
Normann
Posts 277
Normann replied on Sun, Mar 8 2015 10:50 PM
You can use it from Bl3500 also today. I do listen to radio, my music and pattern play thru my bl3500, using my beo4
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 9 2015 5:55 AM
Normann:
Can you explain your setup?
Normann
Posts 277
Normann replied on Mon, Mar 9 2015 7:32 AM
Yes.
Today i have connected it thru a delay box (not operative yet) and to a ML/NL converter.
In the ML/NL converter you can either set it up as A-master or Av-master. I set it up as AV- master and then everything works just fine!
The only thing that is not working (as for now) is the volume controll on the Jukebox on the Moment, and when you switch from example radio to TV, it doesn't shut down.
in A master setup, everything works, except when you starts music, radio in a linkroom the master in the room where the Moment is connected starts playing. These things will get a fix in the updated software in May.
And if you have NL and ML product you can just use one of them, and not both as for now.
I am using the Moment just as my BS5/BM5 setup i had earlier Big Smile
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 9 2015 7:48 AM
Normann:
Yes.
Thanks.
When you say that you have connected Moment to the NL/ML, does that mean that you have connected Line out on Moment to Line in on the NL/ML converter?
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 9 2015 8:00 AM
This is how my system is setup:
Millemissen
Flensborg, Denmark
Posts 14,680
I guess the difference is, that Normann has set his Moment to use the NL/ML Converter, and you have set it to use the BV!
Am I right?
It can't work in both situations by now - the update(s) in May will change that.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 9 2015 8:51 AM
Probably,
I´m just curious how he has connected Moment to the NL/ML Converter.
frank2u
Posts 80
frank2u replied on Mon, Mar 9 2015 3:47 PM
Hallo,
the Netlink seems to based on TCP/IP connection. You have to use a normal network switch for the connection. One cable for the Moment and one for the NL/ML gateway. I was in the same situation first I wondered if this can be true. But it seems to be netlink over TCP/IP.
Frank
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 9 2015 3:56 PM
frank2u:
Hallo,
Frank
I guess thats the way I have it setup. See my drawing in my earlier post in this thread.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 9 2015 3:59 PM
BeoBoy68:
I doubt there will be a MkII, since the software will be updated continuously.
Regarding screen resolution, do you think it actually looks bad or is it that you think its a bad specification? Just curious.
Normann
Posts 277
Normann replied on Mon, Mar 9 2015 4:33 PM
This is right MM.
To my line in on the ML/NL i have connected a Playmaker
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 9 2015 8:30 PM
Normann:
This is right MM.
So how did you connect the moment to NL/ml converter?
StUrrock
Posts 995
Hiort:
As sure as the Sun always rises in the East, the MKII always follows the special edition of the MKI Big Smile
StUrrock
Posts 995
Hiort:
http://mobile.pcadvisor.co.uk/reviews/tablets/3470163/tesco-hudl-review-excellent-android-tablet-with-good-specs-and-better-price-tag/
Once the tablet section is updated to the Tesco Hudl the display should be okStick out tongue
Normann
Posts 277
Normann replied on Mon, Mar 9 2015 10:01 PM
It's not connected with any cable, just over the wifi. If i can remember correctly..
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Mon, Mar 9 2015 10:44 PM
Hiort:
Regarding screen resolution, do you think it actually looks bad or is it that you think its a bad specification? Just curions.
Of course, a MK II version will be available if Bang & Olufsen don't stop to produce the BS Moment.
Look the BS Essence will have a MK II version after 14 months only !
The tablet screen is not well integrated. Angular and square corners would have been more harmonious.
The screen don't have a Retina Display (HD).
Colors are not enough bright for my eyes.
The glass is not anti-reflective and not treated against fingerprints.
Millemissen
Flensborg, Denmark
Posts 14,680
The BS Essence is not NL.
The 2nd Generation of it is NL - that is the reason for the 'new version'.
This does not apply to the BS Moment.
Chris Townsend
Qatar
Posts 3,531
The resolution of the screen although not up to the latest iPad standards, wouldn't really bother me. The fact that I can use my iPad Air all day and not notice a finger smudge, which I couldn't say the same for the Moments tablet.
Then there's the huge elephant in the room, the Moment doesn't support the excellent Beomusic App, but my iPad does. What madness.
Millemissen
Flensborg, Denmark
Posts 14,680
Does your iPad/BeoMusic app turn on the BV respectively the BeoLabs, when you start using it Unsure
StUrrock
Posts 995
StUrrock replied on Mon, Mar 9 2015 11:04 PM
Chris Townsend:
What Madness, What Tueness.
StUrrock
Posts 995
StUrrock replied on Mon, Mar 9 2015 11:10 PM
Millemissen:
No because some mad person has decreed it so!
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Mon, Mar 9 2015 11:45 PM
StUrrock:
Big Smile LOL Stick out tongue
Chris Townsend
Qatar
Posts 3,531
Millemissen:
But what's the point of turning it on, if I can't then search for genres/decades/artists etc on Deezer?
frank2u
Posts 80
frank2u replied on Tue, Mar 10 2015 8:30 AM
Chris Townsend:
This is a good point. I hope this is on the update list for the next version as well.
Chris Townsend
Qatar
Posts 3,531
So do I, and I'm sure it will.
Aussie Michael
Melbourne, AU
Posts 3,730
I got a new iPad Air 2 the other and all I notice is finger smudges - and my hands are clean
Millemissen
Flensborg, Denmark
Posts 14,680
Chris Townsend:
Aha!
You simply want that the BeoMusic app should be the interface on the Jukebox, or?
Chris Townsend
Qatar
Posts 3,531
Yes Yes - thumbs up
Puncher
Durham
Posts 11,729
Puncher replied on Tue, Mar 10 2015 1:01 PM
It's simple enough, the Moment tablet should run a combination of the BeoApp and the Moment software - it should be fully featured and complete. The App should be some subset of this  - it shouldn't be offering features not found on your £1700 device (supposedly designed from the ground up for this purpose)!!
As Chris says, this is madness and needs addressing pronto!
Ban boring signatures!
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, Mar 10 2015 2:44 PM
Today I’m having the Moment also a month. A short thought.
It is exactly what I was searching for to replace my Mac Mini iTunes with Amarra and Audirvana combo.
I now trowed that awfully iTunes completely out of the house. From the beginning, it was always been the syncing that drives me a little crazy. I think of the stuff on iTunes media as my stuff. I’d like to control it. Last year in Cupertino, there’s was a guy with an untucked shirt muttering, “But I thought people liked U2… No, dropping a U2 “gift album” into my iTunes account was over the top with me.
There are off course things that can be bettered as is the search function, a two letter search would be good enough for me with my large library. But viewed in the whole the Moment gives me now that perfect control of my music library and adds simplicity of operation for the whole family. Just waiting for that multiroom and I can say, well done B&O!
Page 1 of 22 (864 items) 1 2 3 4 5 Next > ... Last » | RSS
