One month with the Moment
This post has 863 Replies | 16 Followers
propaganda
Posts 119
I am not sure about the veracity of information regarding a software re-write for the Moment. On the B&O product page for the Moment it lists an American company Tectonic (GoTectonic.com) as responsible for the "Interaction, Visual and Motion" Design rather than B&O themselves. So who knows what is actually coming. It seems that B&O did not do an in-house job after all.
Even more depressed re: the Moment....
Millemissen
Flensborg, Denmark
Posts 14,680
Tectonic works for/with a lot of companies.
One of these is Samsung!
Now tell me, that they are responsible for all, that is Samsung branded.
They worked for Amazon as well.....
Of course every company for their products let things do by other companies, that have more expertice. (With one exclusion: Apple - they buy the companies they need!).
This is nothing new, really - most companies have always bought physical component for their products from other companies - and still do.
dueno
Posts 101
dueno replied on Wed, Jun 17 2015 3:26 PM
My experience with moment after three weeks.
I have 22000 songs in itunes (apple lossless) on my mac.
I use twonky to work with the Moment
It takes a day for the moment to analyse my library.
Deezer works fine with the moment, you have access to your playlist, radio of your artist and deezer radio, playlist done by deezer and the playlist of your friend on deezer(very good).
I have access to all my itunes library too
Nix the BUGS i have:
- album artwork are cropped and there is a blur effect on them. Blur effect on artist photo too
- my itunes playlist are inverted first track become last.... So i created inverted playlist on itunes
- when you do a change in itunes new playlist or album you have to erase all in the moment and one day to analysis the library SadSad
So I think when good software will be done the Moment will be perfect!!!
Do you know if one update is this week 25???
dueno
Posts 101
dueno replied on Wed, Jun 17 2015 3:29 PM
I have forget
In the playlist if the file path of a track has é or è character the track will not be in the playlist bu that is a twonky bug no b&o!!!
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Wed, Jun 17 2015 3:31 PM
Millemissen:
This is true of car companies too. Most car companies now make only the shell and buy everything else in from specialists.
If you have a diesel there's a good chance it has an engine actually made by Fiat. And most diesels, in turn, have inlet manifold and swirl valve systems made by German company Pierberg. And most of those systems are notorious for failing, particularly BMW's who in their wisdom asked for stainless steel swirl flaps instead of plastic.... So that when a valve fails it is injested  by the engine causing thousands of pounds worth of damage.
Sorry about the Off topic rant, but it is true that most manufacturers are now totally dependent on each other, and when there is a major design fsult it csn go on for years and affect many many products by different manufacturers.
Graham
Sal
California, USA
Posts 1,197
Sal replied on Wed, Jun 17 2015 3:37 PM
dueno:
This is, to me, likely the most unacceptable of all of the bugs folks have stated here, and to my knowledge the first I've heard of this.
Likely the one which would cause me not to consider a device like this at all. I do understand the need for the Moment to analyze for the mood wheel, etc. But a small change should merely be compared/added to the last full analysis. Surely this is low hanging fruit for the next version of software to address.
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Jun 17 2015 4:37 PM
Sal:
This will also be a feature of Windows 10: If you create a new excel sheet you have to create all existing sheets again.Big Smile
Räuber
propaganda
Posts 119
Millemissen:
What exactly is your point here. Tectonic are responsible for the UI of the Moment as it stands regardless of who elese they may consult to.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Jun 17 2015 6:42 PM
Raeuber:
This remark falls in a category like: "what is the color of grass? .........."cow".
Millemissen
Flensborg, Denmark
Posts 14,680
propaganda:
Millemissen:
When you ask someone else to do a job for you, you usually tell them, what you expect from them, how the main concept should be.
Besides, the BeoSound Moment is more than just a UI.
Imo - the concept of the BS Moment originates in the ideas, that B&O have worked at for some years now - no matter which company made the actual UI.
May I ask you, what is your point of posting this already known fact here?
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, Jun 17 2015 8:27 PM
Millemissen:
Which was my point about the importance of thorough, testable requirements and documentation, something which in the commercial world is not often done as well as in aerospace and such. Hard to tell if this is a case of bad requirements, bad execution, or more likely a combination of both. It's possible the hardware was chosen with a certain file size structure in mind and hiccups with larger, it's possible it's s/w, it's possible it's both. All that's readily apparent is that there are problems.
Jeff
StUrrock
Posts 995
StUrrock replied on Wed, Jun 17 2015 8:34 PM
Carolpa:
If only the B&O product concept department asked such pertinent questions.......
propaganda
Posts 119
Millemissen:
I was not aware of that fact. Another poster suggested that a new American irm had been drafted in to rewrite the Moment software. I wondered whether this information was accurate or merely a rumour. I think that is a fair reason to post.
I also did not quite get your post. I do now - it was a fair point, although it seemed somewhat argumentative to me. Sometimes I find your comments quite abrasive and unhelpful.
Sal
California, USA
Posts 1,197
Sal replied on Wed, Jun 17 2015 10:19 PM
Hmmmm, I'm certainly hoping that the entire package is taken into consideration with the Moment. Treating the UI and core functionality as two separate entities means that even if the UI is improved, bugs with the core functionality go unaddressed. I'm hoping that the company in California have the authority to address both, rather than merely the UI.
One example of my point: A smooth and usable UI doesn't mitigate the need for a complete device "restart" or similar with minor changes to the libraries it has access to.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Wed, Jun 17 2015 11:11 PM
BeoMotion:
Just found this on the fccid site: LINK
You can see that the heart of the moment tablet is a Tegra 3 SoC from nvidia. It was introduced in 2011 and I've only heard of bad user experience with devices using this chipset. I have an old (2011) asus android tablet with exactly the same core. It feels like the moment. It is slow, it crashes and reboots sometimes but has a much better display :-)
Unbelievable that Bang & Olufsen can sell so expensive a poor tablet with a 4 years old technology ! No - thumbs downNo - thumbs downNo - thumbs downNo - thumbs down
Millemissen
Flensborg, Denmark
Posts 14,680
BeoBoy68:
As far as I am aware B&O is not selling any tablets.
They are selling a NL-based BeoSound, which has a detachable control unit.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Thu, Jun 18 2015 12:29 AM
Millemissen:
LOL Big Smile
@ MM
your way to defend Bang & Olufsen is really laughable !
Paul W
London
Posts 1,810
Paul W replied on Thu, Jun 18 2015 1:06 AM
MM c'mon man - this is a basic tablet based system. The whole 'thing' will of cost less than £280 (450Dollars) to make including the DAC. Cheating customers with this kind of rubbish is a disgrace. I sincerely hope that BANG&OLUFSEN do go bankrupt. They've been incredibly dishonest with this bag of rubbish. If there's one thing that i've learnt in business and through life, it's be honest and respect your clients and give your 100%. BANG&OLUFSEN have truly shown to do the opposite. They're a true disgrace and my word, my opinion of Tue has certainly gone down after he signed off this product.
I truly feel genuine sorrow for any person who has bought into this system. They should demand their money back and shop elsewhere.
Beroli
Germany
Posts 316
Beroli replied on Thu, Jun 18 2015 5:41 AM
Even if I am not happy with my BS Moment, I really don't hope, that B&O will go bankrupt. I had no trouble to pay good money for the Moment at all, even if B&O glued some third-party-parts together - as long the final product will work as promissed and advertised. But it doesn't. Therefore I am angry and frustrated. Therefore I feel cheated. I love my BeoLab 18, the new Remote One, the A2, A8, H6 and the many other things I own from B&O, even if I don't know who delivered the inside-parts in the end. They work as assured - thats all what I want. In a global market you can not produce anything by yourself. The screen in my B&O TV is from Samsung, Phillips provided the screen for my first BeoVision. I never had the Idea to compare the Beovision to any Samsung or Phillips-TV, because the BV came with additional great functions like Multiroom, PUC, Motorstand... - and yes a BV delivered the core basic functions as well.
Nowadays it is different, the BS-Moment does not deliver basic functions of a Streaming-Device, like showing track-embedded-covers from every DLNA-Server (not only Twonky) instantly. The file-processing duration is a bad joke. More than !!!!ONE!!! day for 24k Tracks - and finally without/wrong Covers, missing titles.... Yes Twonky works better with the Moment regarding the covers, but the processing is still disgraceful for B&O. Most of the time you will need to force the BS Moment to another day-eating  processing, if you decide to change a playlist or if you add/remove some Albums/Artists.
Even if I know Apple would never provide his iOS/ Tablet as a Modul for the Moment, there are plenty good Android-Modules with decent Software out there. They show every track including all track-informations instantly. They can handle Spotify and Deezer as well - but in the end I don't want to use a normal Android-Tablet as the main B&O Soundsystem. Therefore I was looking forward to the Moment. So really I enjoyed having a look on the Inner-parts of the Moment in the document provided above - what I don't enjoy is the final unfinished product. I like the design of the Moment -live with it -Tastes are different :-)
B&O had a hard financial time in the past. Therefore I don't understand why B&O destroys the groomed good product image on purpose, by throwing this unfinished, buggy, faulty and lame BS-Moment at their customers - when so much is at stake.
Cheers Beroli
just for MM: for the Easy-only-Deezer/TuneIn-Listeners with small music-collections on a Twonky-based-Server - the Moment is a perfect match, no need to improve everything. The other complaining guys just "hold the Moment in a wrong way" and "don't understood" the product in the first place. Yeah!!!
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Jun 18 2015 7:44 AM
Paul W:
+1
Except: I don't want B&O goes bankrupt, although I fear it will happen. I only want a new CEO, Tue is distroying this company from day one. This guy has no idea of the soul of this brand and the preferences of their customers. I'm sure he didn't check the Moment before launch, but he is responsible for this disaster.
Regards
Räuber
frank2u
Posts 80
frank2u replied on Thu, Jun 18 2015 8:12 AM
I just want to share my experience with the Moment. I love it. No reboots.
First I started with DLNA. And yes, the Moment had problems with the covers. But why using DLNA? I started to add all of my albums as favourites in deezer. Only a few artists were not available. In sum I have only 50 songs still on my NAS available via DLNA. This is working very well.
I hope that in future it is possible to search directly in deezer with the Moment. And we will see a better integration in NL/ML configurations. Now the speakers in the main room switch on when you hear music in any link room.
All in all it is possible to use it now. And an update is on the way as I read hear in the thread.
Frank
Millemissen
Flensborg, Denmark
Posts 14,680
BeoBoy68:
LOL Big Smile
@ MM
You may laugh - then maybe we can at least agree on laughing at each other Stick out tongue
Aussie Michael
Melbourne, AU
Posts 3,730
Tue is fine.
Regardless of who did the UI it's Bang & Olufsens name on the product and they are the creators and should have done better quality control.
I understand the need for outsourcing and it add expertise in areas where they may not know, but the quality control should be in house - they are the ones that should know their customers.
Culturally the company is sick. On Twitter a customer asked when B&O is going to fix their issue with deezer in their moment. After the first post with no reply the customer asked again. B&O responds sorry we have passed on to the product development team and we can't help you any further. That's disgusting. Get your finger out and find out before responding to the customer. It's your customers that pay your wages. It's that clear.
With the upcoming multi room I have a feeling that the software will be something special. It's a real opportunity for B&O to get it right. Giddy up B&O :-) Lets have a Party !!!Yes - thumbs up
Chris
Ostend-BE
Posts 1,170
Chris replied on Thu, Jun 18 2015 10:30 AM
Ahum... anybody notices the V1, BV11... update today?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Chris
Ostend-BE
Posts 1,170
Chris replied on Thu, Jun 18 2015 10:33 AM
Ahum... anybody notices the NL/ML converter ... update from June 11?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jun 18 2015 10:54 AM
Because of start-up problem I used the same Twonky Server as for the BS5. I intentionally wanted to use the server of JRiver instead, but had some problems with the artist pictures (totally not with the embedded covers though).
Triggered by this discussion I retried today JRivern. The Moment reads the content of the server within 10 minutes (approx. 16.000 files). The covers are shown on the BeoMusic app right away. The Soundhub takes more time. How long? No info displayed after 15 min! So presumably the way the heart and the hub communicate will be the cause of most issues.
So the solution would be to fit a tweaked Android version of the BeoMusic app in the Soundhub
Since the start I used the BeoMusic app more than the Moment itself. It is simpler and has a good UI.
For me the Moment delivered what was promised at that moment. And yes I have had my share of problems, but still it did what was said. What I miss a lot is the multiroom functionality. I'm used to take the music around the house with me. So bring it on................ I like what I see in the the BeoMusic beta app.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jun 18 2015 10:56 AM
Chris:
that is the release date of the sw. The update was today, as the updates for the BV
It's the start for the new multiroom (at least the BLC update). No new update on the Moment, anyway I didn't seen it
Aussie Michael
Melbourne, AU
Posts 3,730
Chris:
I just did the update on the avant. Took a little while. Was for the picture on when listening to a picture source and for the hbbtv "
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jun 18 2015 11:03 AM
Aussie Michael:
Chris:
there is more:
You can choose to leave the screen on with Homemedia f.e.
an issue with music delay has been handled; new item in setup-product intergration
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jun 18 2015 11:10 AM
Addition: after 30 min the Hub of the Moment started to fill with info from the JRiver server. It seams to go really quick now.
 So some problems seams to been solved
 Beroli maybe you should (re)check your local network, maybe you have some issues there.
Beroli
Germany
Posts 316
Beroli replied on Thu, Jun 18 2015 12:04 PM
Hi Carolpa,
my local gigabit network works flawless with stable transferrates. That was the first thing I checked, after it took the Moment over a Day to process the music-folder. It takes about 40 Minutes to copy 160GB from my NAS to the macmini - so, no issues there. Maybee, next week I should try JRiver too. The only thing I don't want to do is buying license after license just to find out, that the BS Moment won't work again. I am really gratefull for your advices. Thank you and please keep us posted about your longterm experience. :-)
Cheers Oliver
Beroli
Germany
Posts 316
Beroli replied on Thu, Jun 18 2015 12:54 PM
Really? You do see a check mark in the Moment-settings after 10 Minutes - for 16.000 files? I had this before and afterwards I realized that the Moment simply stoped the processing and most of the files/playlists from the server were still missing - but the checked mark showed up. They only thing what was filling up, where the tracks from deezer (including artists and album-covers). Please check if you didn't only see the content of Deezer instead your files. You would be the first customer who could get the processing of 16k files done in 10 Minutes on the Moment.
I am sure you meant the deezer covers or you were connected in the BeoMusic-App to the JRiver-Server instead to the Moment. The BeoMusic App is not the Moment. Most important is that all your music (including your Server) is shown on the Moment.
I don't understand what you mean. The Soundheart and the hub/base are the same. The Moment is the combination of the Hub/Soundheart and the Jukebox (Tablet). You can only see the progress on the Jukebox. If you put back the settings-plate on the Soundheart before you see the check-mark on the Jukebox-Display under processing, you will mostly interupt the initial processing. The Moment will try to proceed with the processing, but slower. Foremost it will only add the changes in Deezer. Therefore I don't know how you could recognize a difference between the soundheart and the BeoMusic-App. Maybee you choosed on your BeoMusicApp your JRiver-Server instead the BS Moment. I am sure, if you choose the BS Moment in the App you will see, that your content is still missing on the Moment after 10 Minutes.
So the solution would be to fit a tweaked Android version of the BeoMusic app in the Soundhub.
that is what I mean. The processing of a Server is almost instantly done by every app regardless of iOS or Android. Only the Moment is doing some "magic" processing that will need days.
If I intended to use my iPad/BeoMusic-App as a main input for a Soundsystem, I would have never bought the BS-Moment. Sadly the BeoMusic-Apt is nowadays the only usefull crutch to use the Moment. And yes I dont understand, why they didn't used the same UI for the Moment.
cheers Beroli
koning
holland
Posts 4,220
Trust Me......there's nothing wrong with The Beosound Moment (lol)
Paul W
London
Posts 1,810
Paul W replied on Thu, Jun 18 2015 3:43 PM
That's right, they are the funny characteristics that you get with BANG&OLUFSEN products ;)
Millemissen
Flensborg, Denmark
Posts 14,680
Chris:
I already made a thread on that!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jun 18 2015 4:43 PM
Beroli:
Note: as I wrote, I see the files on the BeoMusic app in that time. The Hub needs more time! Almost all albums I checked are complete, including embedded covers. I notice two who were not complete. But they are dsf files (SACD)which have to be converted to pcm by the Server. I presume there is something other going on with these. I hardly have used Deezer with the Moment until now. Yes they can be seen right away but they are a very small minority
NO the embedded covers in the files from JRiver. The Moment is the Soundheart; the Soundhub is just the UI. Thus the BeoMusic app has more similarities with the hub than the heart.On the moment the music files are shown in the BeoMusic app you can control the music. For the hub it takes somewhat longer. But even that seems to be at a reasonable pace.
 No in my opinion the actual "sound processor" is the Soundheart. And it works quite quick to collect the information from the Server. As said before after about 10 minutes I can access my complete collection in the BeoMusic app. The hub is only a UI for the Moment.
I see my complete collection and I can access all the files, at least I did some testing and I always got instant music (taken in account the normal time between a switch from one album to the next)
Only part of the Moment; the Soundhub; but even that seems fair with my settings and system
cheers Beroli
see my remarks
Paul
lonfred
Posts 200
lonfred replied on Thu, Jun 18 2015 4:48 PM
Seems that there at least are one Bagdad Bob in this forum. No names....
StUrrock
Posts 995
StUrrock replied on Thu, Jun 18 2015 5:01 PM
koning:
Beroli
Germany
Posts 316
Beroli replied on Thu, Jun 18 2015 5:13 PM
@ Carolpa
now I'm getting your point. You see your JRiver-Server-Content much earlier on the BeoMusic-App, while the ui is still processing the files. Right? Therefore you think that there is just something wrong about the communication between the hub and the tablet (ui)? But regardless of this known issue, you are sure that using JRiver could be a better, quicker solution than Twonky in regards of the first-setup processing.
I will try it 😎
Cheers Beroli
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jun 18 2015 6:27 PM
Beroli:
@ Carolpa
I will try it 😎
Cheers Beroli
Right! but maybe there is nothing "wrong"  with the hub it self, then solemnly sw issues.
I do not have the impression it has something to do with Twonky. Note: that originally JRiver didn't work to my satisfaction when I started to use the Moment.
If I have time I will re-switch to Twonky. But I think/have the impression that the effect will be the same.
Correct me if I'm wrong but I thought the try-period of JRiver is 30 days, so you'll have plenty of time. The PONO sw for MAC/PC will work also (search for it on the forum of JRIVER) it will work till September. In principle it is the same Media Server, but then only limited to Audio. To my knowledge it will do the trick also
 regards,
Paul
Page 10 of 22 (864 items) « First ... < Previous 8 9 10 11 12 Next > ... Last » | RSS
