I have just bought a new 11-46. Last night after switching it off i noticed that on standby if you touch the aluminum frame (around the TV) it feels weird. It's almost like there is a low electrical current going through it. If you put your ear to it you can also hear a slight hum. Is this normal or is it communicating with aliens?
LR2015:I have just bought a new 11-46. Last night after switching it off i noticed that on standby if you touch the aluminum frame (around the TV) it feels weird. It's almost like there is a low electrical current going through it. If you put your ear to it you can also hear a slight hum. Is this normal or is it communicating with aliens?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: Could be that the fans run for a while after it goes to standby. But if you feel something strange when touching you should have B&O to take a look.
Mmmm. I think i'll ring the B&O store. Cheers
I dont think the BV11-46 has any fans...
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
I consider that a feature of aluminium in a mains powered unit. I have yet to see completely satisfying explanation, but I can feel the same on many aluminium frames and casework from early '70s Beomasters and Beograms to some later kit.
--mika
tournedos: I consider that a feature of aluminium in a mains powered unit. I have yet to see completely satisfying explanation, but I can feel the same on many aluminium frames and casework from early '70s Beomasters and Beograms to some later kit.
It doesn't feel like anything is wrong - just a weird sensation. I can only feel it with the back of my hand when i move it across the frame.
LR2015: It doesn'tfeel like anything is wrong - just a weird sensation. I can only feel it with the back of my hand when i move it across the frame.
Then I'm pretty sure we are talking about the same phenomenon. It requires movement and only the slightest touch. I have many pieces of B&O kit that do that (including my pair of BL8000s I think) and there's nothing wrong with them.
But if nobody else says they have felt the same thing on a BV11, I guess it's worth discussing with your dealer just for the peace of mind.
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
