How to replace covers on Beolab 9 ?
This post has 7 Replies | 0 Followers
Hereford
Posts 87
Hereford Posted: Sat, Mar 21 2015 9:36 AM
I've been searching around a bit for the answer and came upon this old thread: http://archivedarchivedforum2.beoworld.org/forums/t/18804.aspx
But the linked guide within is no longer available.
tompa
Posts 64
tompa replied on Sat, Mar 21 2015 10:07 AM
Pull off the black plastic back of tweeter (carefull so you not do any marks) then you see the screws after that just lift off the speaker/lens unit complete, then this done just lift off cover.
Hereford
Posts 87
Hereford replied on Sat, Mar 21 2015 12:47 PM
tompa:
Ah okay, so thats how it's done. Are there any other warnings before I get to it?
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Mar 21 2015 1:44 PM
If I remember from when I put mine together it takes a really weird sized allen wrench (hex tool) to take the tweeter screws out, something like a 2.5 mm. Strange size.
Jeff
Hereford
Posts 87
Hereford replied on Sat, Mar 21 2015 2:04 PM
Ok that was extremely easy. I just gained even more respect for B&O's engineering and design.
You were right that it was a 2.5mm hex thingie. That and a pointy plastic thing to squeeze the top cover off was all that was needed.
The speaker looks very badass naked. That small tweeter unit is very heavy.
Hereford
Posts 87
Hereford replied on Sat, Mar 21 2015 7:43 PM
Some pictures from the procedure
Dave
Posts 128
Dave replied on Sat, Mar 21 2015 9:13 PM
Funny, you are doing the opposite to what I wish to do! I have had white for 5 years now and I want black instead so I don't have to worry about scuffing them. Where are you located?
Hereford
Posts 87
Hereford replied on Sun, Mar 22 2015 8:43 AM
Dave:
Denmark. I'm not selling the black ones though. I expect to switch around every now and then.
Page 1 of 1 (8 items) | RSS
