I am looking into getting a BS3 paired with a current 65" or 75" 4K samsung LED. Should I look for the latest (MK 3) version of the BS3 or will an earlier MK 2 or 1 do? How do I identify a MK 3 (based on serial number?) I don't care about 3D capability and realize the BS3 (or BS4 for that matter) do 4K processing
Thank you
Any benefit of looking for a MK2 or MK3 or will the MK1 do fine to drive a new Samsung LED TV? What are the main differences between the MKs?
Mk1 - first version, Mk2 has Freeview as standard, Mk3 is 3D.
Not sure about any processing capability improvement (aside from 3D on the Mk3). The Mk1 can be software upgraded right up to the last/latest version, so I'd probably go for a Mk1 and have it done.
Lee
Was there a physical hardware update? I think the MK3 has HDMI outputs whereas the MK1 has DVI outputs (not sure about the MK2) which may be relevant as most TVs don't have DVI inputs anymore (although I guess you could use a DVI to HDMI adapter)
Is Freeview an EU or Uk specific feature? I am loacted in the US
No, they all had multiple HDMI outputs right from Mk1 up to Mk3.
I'm not actually sure about the Freeview thing! I doubt a European spec. Freeview module would work in the US as the frequencies are very different...
PS - also remember the voltage differences!
Ah, you know... A little B&O here, a little there
turbotol: Is Freeview an EU or Uk specific feature? I am loacted in the US
"Freeview" is British for DVB-T. It's not going to be of any use to you in the States.
--mika
