Dear Friends,
I am owner of a Beomedia 1 connected with my 7-40 TV.
It is some time now when I start the oprtion PC( for the Beomedia) in my TV, a red light appears down on the right corner that does not dissapear.The beomedia responds(you can listen to the music or what else) only to my keyboard commands and not to my Beo5 commands.
Any idea???
Dear All, dear geotsialos,
Did you find a solution to this?
I am facing the same. My BeoMaster5 is connected to the BeoSystem3 via ML, DVI and SPDIF. There is a red dot lower right on the main menu and the BM5 is not responding to any comands from the Beo4 when it controlled from the BS3 which is video master (V.OPT.2) via the PC command. BM5 is not connected to LAN/WLAN. I can control the BM5 via a USB keyboard with a picture on the screen and sound via the SPDIF. However, I don'¨t know how to enter the configuration menu this way.
I know there is a ML connection to both BM5 and BS3 as I can control the BM5 via the N.MUSIC command, but without picture.
I have tried a recovery of BM5 with no luck.
Any suggestions?
