It doesn't stay green it fades away after a few seconds, When i had my beolab17s they did this also.
Beoplay A2
Wow that's weird, I've heard both the lab 9s and the 20s and i can assure you the 20s are amazing. Before i brought my 17s i demoed the 20s and the clarity depth and bass weight really impressed.
I really think the dealer had something set up wrong. However, I emailed them and inquired about the possibility that things were not set up correctly, possibly the 20s were not even on. They have not emailed me back so I am guessing they were connected properly and on but for some reason did not sound good. (or dealer does not want to admit their mistake LOL)
markiedee:It doesn't stay green it fades away after a few seconds, When i had my beolab17s they did this also. Beolab14 2.1
With a wired connection, the green led comes on for a few second every time your turn on the speakers, then it dims after a few seconds.
I am not sure with a wireless connection, but I believe it is just the same.
So.... the dealer arranged you with a demo where the speakers sounded like crap, and are uninterested in finding out why that would be?
Are they possibly trying to sell you something else instead?
--mika
js:then it dims after a few seconds. I am not sure with a wireless connection, but I believe it is just the same.
If it's the one without the glowing bang-olufsen logo then it starts with the green light then dims to off.
Slightly off-topic, but here is a pretty detailed - and very positive! - review of Beolab 20. Be advised that it is in Danish though!
http://www.lydogbillede.dk/test/bang-olufsen-beolab-20/
Cheers,
VANTAGE
Current: Beovision Eclipse 65" v1 - Beolab 50 - Beolab 28 - 2 x BS2 (GVA) - 1 x BS1 (GVA) - Beoremote Halo - H9i
Past:
Beovision MX4000 - Beovision 3-32 - Beovision 7-55
Beosound 9000 - Beosound 5 / Beomaster 5
Beolab 6000 - Beolab 8000 - Beolab 5 - Beolab 3 - Beolab 17
Really enjoyed reading that review.
Looks like a great review to read, if only I read Danish.
@Ratzlaw
A lot of my fellow-danes rely on Google Translate, if they want to read reviews in english.
Just you try that out!
....even if the 'trans-englished' text may be a bit hard to follow.
Millemissen: @Ratzlaw A lot of my fellow-danes rely on Google Translate, if they want to read reviews in english. Just you try that out! ....even if the 'trans-englished' text may be a bit hard to follow. MM
I think a lot of people rely on Google Translate. I was really impressed with the review and will definitely visit a dealer to listen to the Beolab 20s. I have been concerned about Bang & Olufsen continuing to stay in business but I think I will throw caution to the wind. I think I may still have the Beovirus.
I wonder if the illuminated logo is the only change to the speaker since the introduction or if other "enhancements" have been made as well?
linder:I think a lot of people rely on Google Translate. I was really impressed with the review and will definitely visit a dealer to listen to the Beolab 20s. I have been concerned about Bang & Olufsen continuing to stay in business but I think I will throw caution to the wind. I think I may still have the Beovirus.
Thanks for sharing that review- really useful and fully in line with my experience!!
