New BLGW software...
This post has 22 Replies | 4 Followers
PhilLondon
London
Posts 3,637
PhilLondon Posted: Fri, Apr 10 2015 9:18 AM
Changes in BLGW 1.2.0 since previous BLGW SW version 1.1.0:
  • Added support for the creation of scenes and timers from the BeoLink App (User Macros).
  • Added secure remote access from BeoLink App to BeoLink Gateway (using Khimo.com service provider).
  • Added support for ifttt.com when remote access is enabled, allowing to select scenes directly from IFTTT events.
  • Added system modes, allowing the definitions of macros that only work in some modes (e.g.: Vacation mode).
  • BeoLink Driver:
    • Added channel selection command to simplify the selection of channels from BeoLink app.
    • Change MasterLink reconfiguration to be performed only when booting from power failure
  • Added the following new drivers:
    • Nest driver (without realtime status)
    • Smarthouse/Bticino SH2 driver
    • GlobalCache, drivers for the following global cache systems
      • IP2IR
      • IP2CC/WF2CC
      • IP2SL/WF2SL
  • Changes on Setup page:
    • Added support for different temperature units, configurable in [ Setup ? Units ]
    • Added programming reports [Admin ? Tools ? Programming Report]
    • Changed drag and drop implementation to be touch-friendly.
    • Added a shortcut for quick save and synchronize of publishing information [Ctrl+Shift+S].
    • Cleaned up the system logs, keeping only the useful logs for the installer.
  • Other minor changes and improvements:
    • Extended DIMMER resource type to support color set and status (e.g: allows to set a color to Philips HUE from BeoLink App).
    • Radio Ra2: Corrected the detection of LED changes when loaded resources were present.
    • Home Control TV: Added an option to configure a default zone
    • Improved error reporting with online service report
  • As usual, this release includes several errors and improvements in overall experience.
Beoworld app with direct photo upload and emoticons.
PhilLondon
London
Posts 3,637
...  but it doesn't download!
beojeff
USA
Posts 2,012
beojeff replied on Sat, Apr 11 2015 2:31 PM
That's nice to see the added support for Nest. Sadly, I doubt there will be any legacy driver provided for the MLGW. However, after having Nest for a year and a half, I find that by now I very rarely need to adjust the thermostat. Nest does a great job of learning your preferences. I wonder if the driver will utilize the Nest and Nest Protect occupancy/vacancy sensors to use as macro triggers.
Seanie_230
UK
Posts 2,278
Morning
i will attempt yo update today
i have two nest protects so it will be interesting to see if they can connect.
it does say nest is not a live interface.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Apr 12 2015 11:30 AM
Morning again.
My software update completed fine.
Took around 5 minuets and it felt like a lifetime.
More options are available in the setup page. i cannot see any change to channel selection.
Nest only appears to be the thermostat not the smoke alarms.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
PhilLondon replied on Sun, Apr 12 2015 11:36 AM
For me, it gets stuck at "Preparing to Download..." :-(
PhilLondon
London
Posts 3,637
PhilLondon replied on Sun, Apr 12 2015 11:43 AM
Ah... I just had to reboot the BLGW, and it's now downloading fine...
PhilLondon
London
Posts 3,637
PhilLondon replied on Sun, Apr 12 2015 11:58 AM
It's installed... but I do not seem to be able to pick macros in the left column on the Macro screen...
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Apr 12 2015 12:27 PM
I will try in a moment and feedback
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
PhilLondon replied on Sun, Apr 12 2015 12:33 PM
It's all ok for me now...
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Sun, Apr 12 2015 12:36 PM
Excellent. Everything seems to be running as it was.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
PhilLondon:
  • BeoLink Driver:
      • IP2IR
      • IP2CC/WF2CC
      • IP2SL/WF2SL
Hi there
these all look pretty good.
Nest drive is for thermostat only
Smarthouse stuff looks pretty good but i am not sure if it is dealer install only.
the Global Cache stuff looks to give IR, Serial and relay control from the gateway over ethernet.
This might be great for blinds, screens etc.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Found my first issue.
None of my essance commands are doing anything anymore
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Well the commands are working from the app not the essance. Checked the essance and it is sending commands as when BLGW in capture mode the commands are picked up.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Steven_London
Posts 51
I updated to the latest version of the BLGW software yesterday and am really starting to regret it. Pretty much everything has stopped working.
First issue, the fixed IP address I have selected was lost, the BLGW started using a DHCP assigned address, luckily I have seen this issue before and managed to get the leased address from the DHCP server so could connect to the gateway and change the IP address back to the fixed one.
Next issues more serious:
I have programmed the gateway to control Rako lighting using a RS232 bi-directional interface, the inbound commands from this interface are no longer recognized. Thus all macros I have configured to read wall plate button presses no longer work. When Capturing events all button presses appear to be sending the same string which means the gateway cannot distinguish between rooms and scenes, brilliant!
In addition to this, I also had Beo6 light commands set-up to work the Rako scenes in each room. The macros no longer responds to the remote control, so can only be triggered by the IPhone App, looks like the events need to be recaptured for all zones.
Finally, I have Somfy blinds working via a Raspberry Pi, which acts as a bridge to the RFX433E controller (which worked great). The BLGW talked to the Pi using IP connection, this now seems to be unable to connect. Again looks like the set-up needs to be redone from scratch. It has also locked up one of the RS232 ports, which I had earlier tried to use for Somfy direct and failed. But now cannot be reassigned to another product.
Final issue is remote access to the BLGW. This I had achieved using NAT port forwarding on my router. Now the iPhone app cannot connect to the BLGW and when it finally does there are no zones available. This is really annoying as I don't see the need to use the new remote access functions, its just not required.
So probably going to factory reset it this weekend and start rebuilding from scratch and hope it works a second time, if not anyone know if it is possible to downgrade the firmware to the previous version.
Really not happy with this software release, it really seems to have a number of new features which is great but was there no regression testing done. Feeling very let down by B&O at the moment.
mjmedlo
Posts 922
mjmedlo replied on Fri, Jun 26 2015 2:55 PM
Call BeoCare.
They might email you the previous version.
Steven_London
Posts 51
Hi Everyone,
Wanted to post a follow up regarding the issues seen previously with the upgrade of the BLGW software. Over the weekend, I had a clear out of macros which were little used meaning that the set-up is now far simpler.
Some tips to note, for the custom strings defined for Rako and Somfy, I modified the parameters, saved it and then changed it back to the original settings, this did the trick and the gateway now correctly reads input commands from Rako and can connect to the Somfy controller again.
I noticed that commands which had been captured from NetworkLink and MasterLink products needed to be recaptured or manually entered - this was the most time consuming but once these were captured the existing macros worked correctly.
The one thing that still doesn't work however, is remote access using NAT port forwarding. After deleting the fixed gateway from the iPhone app and re-adding it still fails to find the gateway, locally on the Wi-Fi it works fine. Will see what BeoCare have to say about that.
DocLeisure
Posts 101
Hello,
any news about the NAT port forwarding issue?
If it is really the case, that a Khimo account is needed for remote access, that would be very annoying, because it always worked with the MLGW. Which would mean less functionality with the new gateway.
Unfortunately it is not possible for “home owner” to get an account at Khimo, at this point in time.
Any suggestions are welcome.
Best regads
Doc Leisure
mjmedlo
Posts 922
mjmedlo replied on Mon, Nov 23 2015 10:05 PM
I have a khimo account as a homeowner.
Just sign up for it on the settings screen
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Mon, Nov 23 2015 11:10 PM
mjmedlo:
Hi there
How have you done this
I went it to settings and it diverts to the Khimo website but only installers can have an account
CheersBig Smile
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Tue, Nov 24 2015 2:43 AM
Seanie_230:
Hi there
Cheers BLGW - Rekindling the love of ML
I just went to khimo.com and created an account.
DocLeisure
Posts 101
thanks for your answers. Yesterday I tried to register at Khimo.com and yes, it worked. I filled out the "installer" form a got a prompt Invitation from the Khimo portal. Interestingly it is a subscription to a trial period (I don’t know how long the trial period is), but one can subscribe for one year at $ 119, which is pretty much for remote access to my gateway. One must say, that the Intention of the portal is not only gaining or granting remote access to home users, but more to give installers the ability to orchestrate a variety of customer gateways in one Portal, which might be worth the money.
I will give Stevens method a try today - if it works, that should do the Job.
(http://archivedforum2.beoworld.org/forums/t/17435.aspx)
Best regards
Doc Leisure
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Sun, Feb 21 2016 4:43 PM
new blgw software. v1.3.0.19353
-including nest protect.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Page 1 of 1 (23 items) | RSS
