BeoNut since '75
I have the same problem
Works very good for me with Beoplay A9 Mk2 since two days ago.
But only after I updated A9 I think. Before it did work but with many difficulties: didn't wanted to send it to sleep, didn't wanted to wake it up, long reaction delay on command etc.
Running it on the iPhone 6 with iOS 8.3 (just to reconfirm that).
AnalogPlanet:Works very good for me with Beoplay A9 Mk2 since two days ago. But only after I updated A9 I think. Before it did work but with many difficulties: didn't wanted to send it to sleep, didn't wanted to wake it up, long reaction delay on command etc. Running it on the iPhone 6 with iOS 8.3 (just to reconfirm that).
No, just directly controlling A9 over home WiFi. Could it be the gateway then?
Sorry, silly me - misread the name of the app. :/ You guys have trouble with Beolink app and I referred to Beomusic app.
it coincided that I had some issues too with the standby mode.
Hi
The App is working until i press the standby button then it crashes. Hope the will fix that already reinstalled the app no change.
every button with confirmation does not work!
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
georgey007:Is there a support site at b&o for complaining ?
http://www.bang-olufsen.com/en/customer-service
I've always found them to be fairly quick in response and helpful with any question. I've sent suggestions for product development which have been passed on too.
Dave.
What suggestion?
Beoworld app with direct photo upload and emoticons.
These things happen when you early adopt iOS updates. In the future before upgrading you may want to consult with B&O direct or your dealer to avoid having to wait on the patch. Most integrators will tell you never to update unless you speak with them first. Don't panic there will be an update rolled out to fix it all. I would imagine that is the same update that will enable some of the features that were added to the BLGW from it's latest update.
Ah, you know... A little B&O here, a little there
