Controlling BeoIntegration with the Apple Watch
This post has 42 Replies | 5 Followers
PhilLondon
London
Posts 3,637
Does your TV support the Beo4 with joystick?
Beoworld app with direct photo upload and emoticons.
frank2u
Posts 80
frank2u replied on Fri, May 22 2015 9:05 PM
No, only the normal one. I have a Beosystem 3 MKI.
I took the Beo4 from my linkroom and tried it in the main room. Wind and rewind is also not working with the Beo4. So it seems to be solved with the PUC and Beo5.
Frank
PhilLondon
London
Posts 3,637
If there's anything you need, just create a macro for in on the MLGW, and you can call it from Force touch > Scenes
You may have noted that lists of channels and icons defined on the MLGW can be accesses from Force touch > Favourites
p.
Page 2 of 2 (43 items) < Previous 1 2 | RSS
