Beocord 1500 type 4113 reel-to-reel
This post has 58 Replies | 1 Follower
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Apr 29 2015 5:10 PM
I need this Smile
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Apr 30 2015 4:03 PM
I think this is more like it! Please Dave, don't tell me I need a Thorens Beogram 3000. Big Smile I KNOW!
Jacques
Ben_S
UK
Posts 631
Ben_S replied on Fri, May 1 2015 9:29 AM
Great photo Jacques, looks brilliant with the Beolab 5000 system! Yes - thumbs up
Ben
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, May 1 2015 2:59 PM
Ben_S:
Ben
It does, doesn't it?
I think the Beocord 1500 fits this old system better than the Beocord 2400. Same veneer, silver VU-meters, hammered grey paint...
I will soon get to the electronics. There are two values of electrolytic caps: 85 µF and 125 µF. I think I'll go for 100 µF blue Vishays for the lot - about 30 of them!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, May 4 2015 12:47 PM
Today, replay head adjustment. An unnerving process this. Especially given the condition or the rubber cushions Surprise And no, it's not Play-Doh Big Smile
There are two for each head, plus two more for the tape guides.
Søren, do you have the same problem?
I replaced the replay head cushions and adjusting it was possible at last Smile
Jacques
Søren Mexico
Mexico City
Posts 6,411
chartz:
Yes, but I am learning from youSmile, as you maybe remember I put mine away after test, I was still thinking about how far I want to go with it, there are small problems with the slide potentiometers, the caps measured good except for 2-3 caps. I will open it again at a later time, get parts and do it all as you do. Did you get new rubber cushions
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, May 4 2015 4:07 PM
I cut small bits out of a silicone hose.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 7 2015 11:10 AM
Hello!
Today I replaced some capacitors.
But first I transformed the radio card (602-L31) into a line input.
I pulled four resistors up on one side, and I removed the two 80 μF caps.
Then I put two straps to short input/output (near the connector). Fully reversible. I just let the old caps there.
I'm sure a line adapter was available.
I noticed that B&O used a lot of solder back then, my desolder braid reel can tell! Stick out tongue The whole thing shouts "quality"!
Then, the caps, values all over the place. Between the 125 μF and the 80 μF ones I settled for 100 μF everywhere!
The only problem here is that one cannot pull out the PCBs completely because the are hard-wired to the other circuits and to the rotary switch.
Record PCB.
Some more... Replay PCB. Two transistors were replaced at some point of the machine's life.
I also did the PSU. No photo, sorry. I replaced the four caps. The big 1000 μF reservoir caps still measured... 1000 μF, with a bit of ESR, but not much. Those were very good quality components.
I also rewired the transformer for 240V operation. Easy enough. Just one bridge to add (the one at right) and move the red wire one notch to the right!
Fist recording. The 'new' line input works.
I had to fabricate yet another cable to link the Beocord's line input (pins 1+4) to the CDX's output (pins 3+5). Angry Oh well.
An AGFA (late 80's) reel is placed on the machine.
Mmm. Very close to the original CD, after a little azimuth adjustment at the replay head. I haven't touched the record head at all - or the bias settings for that matter - and the record head still runs on its old cushions! Big Smile
Jacques
Søren Mexico
Mexico City
Posts 6,411
I will have to go back to my BC 2000, hope to finish my BM 1900 today, admire your work and knowledge Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 7 2015 2:52 PM
Hi Søren, and thanks!
Another video, recording, monitor mode. To give you courage Smile
I too restored a BM1900 two years ago. A little gem, this.
Jacques
Søren Mexico
Mexico City
Posts 6,411
Courage is there and the BC 2000 is a little easier than the 1500 to work with I think, all PCBs comes out, where I have a little doubt is whether to open the slide poties for cleaning or just wash them out with ISP and then treat them with Deoxit, Nice video BTW
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 7 2015 3:08 PM
You know I have a Beocord 2400 too. I left the 10 (!) sliding pots well alone. Not brave enough. Cool
Jacques
Orava
Finland
Posts 991
Orava replied on Thu, May 7 2015 4:47 PM
chartz:
Is that sefl under 400x custom made ?
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 7 2015 5:04 PM
Orava:
Is that shelf under 400x custom made ?
Nope, it is a Target Hifi wallshelf I bought in 1989.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, May 8 2015 9:59 PM
Some more recording tests this afternoon. There is no real difference between source and monitoring. Just a little speed irregularity: the capstan wheel is past its prime and will have to be replaced - well actually refurbished.
Another picture from the web, where the logo is present on the head cover.
Jacques
Orava
Finland
Posts 991
Orava replied on Sat, May 9 2015 5:12 PM
chartz:
Orava:
Kind of matching pair  Smile
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, May 14 2015 10:31 AM
Today, I wanted to repair a crack - thanks UPS - in the dust-cover. The good thing is that it is made of true thermoformed Plexiglas, which means it can be bonded with cyano glue, and residues cleaned with acetone without any damage, unlike later lids which are made of moulded plastic!
So any crack can be filled with large quantities of glue.
It now looks like a scratch. Sorry about the bad pictures, it is very difficult to photograph!
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, May 24 2015 3:46 PM
The final touch... Confused This time with a proper SLR camera, you can enlarge if so you wish!
Can you spot the crack? Whistle
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, May 24 2015 4:00 PM
By the way... Same VU-meters, only inverted (ReVox G36).
Jacques
Page 2 of 2 (59 items) < Previous 1 2 | RSS
