Somfy Blinds Install
This post has 5 Replies | 2 Followers
mjmedlo
Posts 922
mjmedlo Posted: Thu, Apr 30 2015 11:01 PM
All,
Just installed a blgw with soft blinds.
Works flawlessly with custom string written.
Again.. The blgw is seriously under used.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
mjmedlo:
All,
This post is seriously underviewed too, probably because everyone thought it was another kitchen or blind supplier!
More details needed!
Graham
elephant
AU
Posts 8,219
elephant replied on Fri, May 1 2015 10:20 AM
vikinger:
Graham
True !
BeoNut since '75
mjmedlo
Posts 922
mjmedlo replied on Fri, May 1 2015 1:04 PM
Well
Part of the problem is a auto correct on the iPhone!
It's supposed to be Somfy.
They have an rs232 piece that I connected to the usb of the blgw and then I simply used their protocol for controlling rs232 and no problem.
I added 8 separate motors to the system yesterday and it worked perfectly.
BeoGilles
Posts 1
I have just purchased a BLGW as well to integrate some Somfy RTS products using their RS232 URTSII module but I am not getting anywhere.
I know that the URTSII is correctly programmed because when I press the UP, DOWN or STOP buttons then the product associated to that channel responds. I am also using the B&O recommended blue/white RS232 adapter.I have added the Custom Strings system and everything seems configured correctly (green system connection status). I have created virtual buttons to represent the shutters and blinds
As you can see in the attached photo when I try to add the resources under the custom strings system I have 3 options under type and none of those allow me to add the RTS commands such as: 0101UP for channel 1 up or 0108D for channel 8 down.
As I am obviously missing something any and all help will be greatly appreciated.
Thanks in advance,
Gilles
mjmedlo
Posts 922
mjmedlo replied on Mon, Sep 5 2016 2:16 PM
Let me get back to you.
I'm traveling atm.
Page 1 of 1 (6 items) | RSS
