mjmedlo:All, Just installed a blgw with soft blinds. Works flawlessly with custom string written. Again.. The blgw is seriously under used.
This post is seriously underviewed too, probably because everyone thought it was another kitchen or blind supplier!
More details needed!
Graham
vikinger:This post is seriously underviewed too, probably because everyone thought it was another kitchen or blind supplier! More details needed! Graham
BeoNut since '75
I have just purchased a BLGW as well to integrate some Somfy RTS products using their RS232 URTSII module but I am not getting anywhere.
I know that the URTSII is correctly programmed because when I press the UP, DOWN or STOP buttons then the product associated to that channel responds. I am also using the B&O recommended blue/white RS232 adapter.I have added the Custom Strings system and everything seems configured correctly (green system connection status). I have created virtual buttons to represent the shutters and blinds
As you can see in the attached photo when I try to add the resources under the custom strings system I have 3 options under type and none of those allow me to add the RTS commands such as: 0101UP for channel 1 up or 0108D for channel 8 down.
As I am obviously missing something any and all help will be greatly appreciated.
Thanks in advance,
Gilles
