Beosound 3000 no Sound via powerlink
This post has 6 Replies | 0 Followers
twowheel2001
Posts 39
twowheel2001 Posted: Fri, May 1 2015 9:50 AM
good Morning,
is there a Function in the BS3000, where i can permanently mute the Powerlink? my Setup:
BS3000 w/ beolab 2500 via powerlink, beolab 2000 via Masterlink!
after renovation I plugged system in and it worked. I only needed to reset the timer in order to have the beolab 2000 waking ne up in the morning with CD. This works, however even when switching on, no Sound from lab 2500. timer deleted, no Sound! Masterlink works......
Reset via pulling Plug, no Sound! 😱
Went downstairs! Plugged lab3000 on, Display says cd or radio, however  "--" for Sound level...... No Sound.....
i am lost what Else to try!?
thanks for any help!!!!
best regards, markus
Dave Farr
France
Posts 2,283
Quick answer is yes. The 'mute' button on the bottom row on the control panel of the BS3000.
The symbol "--" on you BL2000 indicates that the system has been muted. Press the volume control on your BEO4 or the up and down arrows on the control panel between the mute and standby buttons.
Dave
twowheel2001
Posts 39
Hi Dave,
thanks - but this I found and unfortunatly does not work :o(
Main speakers still not Switch on and no sound! Looks like repair time in shop ...
best regards
twowheel2001
Posts 39
Hi Dave,
best regards
twowheel2001
Posts 39
Hello,
just a quick question - is the board, on which the powerlink, Masterlink etc sockets are placed common with a Beosound Ouverture? Just thinking about buying a spare parts donater with failed cd or glass doors....
Thx in advance,
Twowheel2001
twowheel2001
Posts 39
twowheel2001
Posts 39
Hello,
Just a quick questions, is the rear board w/ Powerlink, Masterlink etc. socket the same as the one for a Beosound Overtüre? If so, I can look for a donating unit with failed CD in order to repair cheap.
Thanks,
Twowheel 2001
Page 1 of 1 (7 items) | RSS
