good Morning,
is there a Function in the BS3000, where i can permanently mute the Powerlink? my Setup:
BS3000 w/ beolab 2500 via powerlink, beolab 2000 via Masterlink!
after renovation I plugged system in and it worked. I only needed to reset the timer in order to have the beolab 2000 waking ne up in the morning with CD. This works, however even when switching on, no Sound from lab 2500. timer deleted, no Sound! Masterlink works......
Reset via pulling Plug, no Sound! 😱
Went downstairs! Plugged lab3000 on, Display says cd or radio, however "--" for Sound level...... No Sound.....
i am lost what Else to try!?
thanks for any help!!!!
best regards, markus
Hi Dave,
thanks - but this I found and unfortunatly does not work :o(
Main speakers still not Switch on and no sound! Looks like repair time in shop ...
best regards
Hello,
just a quick question - is the board, on which the powerlink, Masterlink etc sockets are placed common with a Beosound Ouverture? Just thinking about buying a spare parts donater with failed cd or glass doors....
Thx in advance,
Twowheel2001
Just a quick questions, is the rear board w/ Powerlink, Masterlink etc. socket the same as the one for a Beosound Overtüre? If so, I can look for a donating unit with failed CD in order to repair cheap.
Thanks,
Twowheel 2001
