I have a Beosound Ouverture and Beogram 3500I plug my Beogram on the AUX input of the OuvertureI am sick and tired to plug the Beogram and unplug it when I want to listen to music from my iPhone
I am wondering :
If I connect the Beogram by Masterlink using a MCL connverter, does it will work ?Does my Ouverture will display "PHONO" and reconize the Beogram as a turntable (not only a AUX imput) ?Thank you for reading meRegards from France
Beovision 5, Beosound 3200, Beolab 2000, Beolab 3500, Beolab 4000, Beolab 6000, Beolab 11, Beocom 6000, Beocom 4, Beolit 12
You probably just need an aux input switch box. Hook the iPhone and Beogram to it, and select the source desired.
Thank you for answeringI already think about a switchbox but :
I just can't find a 7pin switchboxI am a little bit lazy : if I need to turn the button, it is the same for me to plug and unplug the Beogram or iPhone
I already tried to use an Y splitter on the AUX input, but the sound is really bad and I need to unplug the power supply of BeogramWhy ? because the datalink cable of the Beogram is an Output, and I don't think it is a good thing for it to get power in (even if it comes from the iPhone)
What do you think about it ?
François: ...I just can't find a 7pin switchbox....if I need to turn the button, it is the same for me to plug and unplug the Beogram or iPhone...What do you think about it ?
It shouldn't be too hard to build a 7-pin switch box if you're handy with tools. But you would still be stuck with a manual switch to select the source. I guess a ML converter should work too, without a manual switch. Maybe others could answer that question better than I.
Did you think about a Beolink active? Connect a BL active to ML socket on your Ouverture, connect Beolabs to Powerlink sockets in the BL active, connect your idevice to PC input, keep the Beogram connected to AUX input. Set Ouverure to A.OPT 0, set BL active to L.OPT 5 et voila...
If you will expand your setup, you can use the BL active as linkstation in an extra linkroom...
Main difference to your converter solution will be, you `ll need an extra ir eye to the active.
As far as I remember oneremote or Bosscom have ipod/iphone docking stations, that can be controled via it`s own ir eye with Beo remotes...
Another option can be the oneremote audio expander. Connect that one to the AUX socket, and you can plug three analog/stereo sources to the expander. The sources can be selected with Beo remotes. Disadvantage: you won`t be able to control your Beogram via remote, just to select the source. I think oneremote.dk is the site..(?)
Stefan
Or buy one of these.
Wouter
Thank you so much for answering
the AUX expender is exactly what I need
I just didn't know B&O have built it
meeci from France
That is correct - you would be very fortunate, if you would find one.
I'd go for one of the the solutions, that Stefan has described above.
Just remembered...
try this one:
http://soundsheavenly.com/bang-olufsen/11--aux-y-7pin-.html
Thank you but I already tried thisit is just a splitted cable : so when I play music from the iPhone, the power goes out of the iPhone and goes into the Beosound, and also in the Beogram !!
The Beogram din is an output and I don't think it is a good thing that the power comes insideAnd when I play a record on the Beogram, the sound is just awful : ridiculously lowthank you for answering
