Penta speaker cloth
This post has 12 Replies | 3 Followers
kiki_1201
Posts 1
kiki_1201 Posted: Fri, Jun 8 2012 5:14 PM
I would like to change the speaker cloth on the front covers of my Penta's, but it seems to be difficult to find a shop where they sell this.
Online I found two webshops 'akustikstoff.com'  and 'conrad.de' where they seem to have some choice. My problem is know what is the correct color for the Penta covers? On screen everything seems to be too light.
http://www.akustikstoff.com/Acoustic-speaker-cloth-different-measurements/Acoustic-speaker-cloth-different-colors-120-x-75-cm::598.html
Does someone have an idea of what could be the correct color? Thanks!
Regards,
Kiki
(Belgium)
Stoobietoo
Exeter, Devon, UK
Posts 692
It is very difficult to compare colours on a PC screen. I see from the store you linked to you can order a sample pack from them. It looks like it includes one of every colour so I would order a sample pack and that should help.
Looking at the screen samples I would think "12" or "13" but probably if there was a shade between those I'd say  "12.5" Whistle .
With the PC screen I would say "12" is the nearest.
Good luck
Stoobie
bwaje
Posts 32
bwaje replied on Sun, Jan 12 2020 10:32 AM
Hi, have you ordered some ? Which is the nearest colour then ?
I have to rebuild my Penta mk2 cloth also…
bwaje
Posts 32
Good evening,
I have received my cloth from Akustikstoff, I chose the coulour "13", and here are the results :
https://photos.app.goo.gl/JoDZkC5hjek8X2n18
The original cloth colour on the left is quite different from the new one on the right, but considering the original one is really old and dirty, it is difficult to compare; however the lining is different too but it should be OK when all frames are changed
bwaje
Posts 32
bwaje replied on Tue, Mar 10 2020 7:09 PM
https
Willem0709
Posts 15
Hey,
How did they turn out, I just finiched my Penta's with Metalic Grey 415.
https://photos.app.goo.gl/7QAaDBDGqUcqr6TV8
What do you think?
Best regards Willem
Stereomensch
Posts 322
I think it looks great. These fabric look better than the old ones.
Probably some purists will hate the "metallic" look. As far as I know, B&O never used fabrics with a metallic look.
But how did you fix the fabrics at the tray? Did you glue it?
bwaje
Posts 32
bwaje replied on Thu, Mar 26 2020 6:04 PM
Wow, great, I am using neoprene transparent glue and it's easy; but the top panel is way more complicated due to its curb; I don't know how to do it without cutting angles...
Willem0709
Posts 15
Thanks,
I did it with Velcro, also supplied by https://www.akustikstoff.com it is extremely thin therefor it works good with the small amount of space you have in the penta cover. they have a instruction video on youtube how to apply it.
Metallic is a specific range in there portfolio, i selected it knowing B&O used brushed stainless steel in order to make the Penta speaker blend in to there surroundings. By using Metallic Grey I wanted to extend this to the front Smile
Willem0709
Posts 15
Thanks,
Jeff C
Phoenix Arizona
Posts 3
Jeff C replied on Fri, Nov 26 2021 10:50 PM
Reviving this old thread.  I am in the US and recently acquired a pair of Mk1 Penta passives.  Just redid the cones.  The cone surround seller provided me with samples for speaker grille cloth, but none come close to the color of the originals.  That said, what WAS the original color?  I can't be certain that these haven't faded a bit over the last 35-ish years.
Thanks.  Also looking for links for updated sources for the material.
Type2702
Denmark
Posts 12
Type2702 replied on Mon, Jan 24 2022 8:58 PM
te right colour is Dark grey, NOT blake
Page 1 of 1 (13 items) | RSS
