I have a Beocenter 1 in the bedroom ( its the same as the Beovision 1 but with DVD built in and FM Radio)
when I press Radio on the Beo4 remote and Menu, nothing comes on the TV screen, my manual tells me that the Radio screen should appear on the BC1 when I do this, but I get nothing, I have plugged the FM Radio aerial into the back of the TV, I have made sure it is in the right FM Antenna socket on the BC1
I am pretty sure we had Radio working on it before in our old house, but that was about 7 years ago.
Have read all the manuals that came with the BC1 3 times tonight, so I hope someone may point me in the right direction for a fix
thanks
ouverture:I have a Beocenter 1 in the bedroom ( its the same as the Beovision 1 but with DVD built in and FM Radio) when I press Radio on the Beo4 remote and Menu, nothing comes on the TV screen, my manual tells me that the Radio screen should appear on the BC1 when I do this, but I get nothing, I have plugged the FM Radio aerial into the back of the TV, I have made sure it is in the right FM Antenna socket on the BC1 I am pretty sure we had Radio working on it before in our old house, but that was about 7 years ago. Have read all the manuals that came with the BC1 3 times tonight, so I hope someone may point me in the right direction for a fix thanks
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
that is a good point, it was linked to my Ouverture via Masterlink originally, super stuff, thanks for the quick reply Michael, will try it out and report back.
I went into the Radio Menu on the Beocenter 1
Radio Setup / Options / Beolink / Linked Radio = YES
so I changed it to NO, and it made no difference, so I know that setting (when set to YES) is really for playing RADIO to a linked room over Masterlink to perhaps an LCS 9000 or 3500 speaker in another room.
Then I played with the Beo4 remote, set A.OPT to 2 and now playing RADIO fine, many thanks for pointing me in that direction.
