FM Radio on Beocenter 1
This post has 3 Replies | 0 Followers
ouverture
London
Posts 263
ouverture Posted: Fri, Jun 8 2012 11:50 PM
I have a Beocenter 1 in the bedroom ( its the same as the Beovision 1 but with DVD built in and FM Radio)
when I press Radio on the Beo4 remote and Menu, nothing comes on the TV screen, my manual tells me that the Radio screen should appear on the BC1 when I do this, but I get nothing, I have plugged the FM Radio aerial into the back of the TV, I have made sure it is in the right FM Antenna socket on the BC1
I am pretty sure we had Radio working on it before in our old house, but that was about 7 years ago.
Have read all the manuals that came with the BC1 3 times tonight, so I hope someone may point me in the right direction for a fix
thanks
Michael
Sweden
Posts 2,578
Michael replied on Sat, Jun 9 2012 12:00 AM
ouverture:
thanks
Perhaps it believes it is linked to another radio-system that it no longer is connected to? In that case perhaps it looks on masterlink instead of its built in one?
You can change the A. OPT to the right setting with your beo4 but I am not sure which mode it should be in.
ouverture
London
Posts 263
ouverture replied on Sat, Jun 9 2012 12:27 AM
that is a good point, it was linked to my Ouverture via Masterlink originally, super stuff, thanks for the quick reply Michael, will try it out and report back.
ouverture
London
Posts 263
ouverture replied on Sun, Jun 17 2012 1:00 PM
I went into the Radio Menu on the Beocenter 1
Radio Setup /  Options  /  Beolink  /  Linked Radio  =  YES
so I changed it to NO, and it made no difference, so I know that setting (when set to YES)  is really for playing RADIO to a linked room over Masterlink to perhaps an LCS 9000 or 3500 speaker in another room.
Then I played with the Beo4 remote, set A.OPT to 2 and now playing RADIO fine, many thanks for pointing me in that direction.
Page 1 of 1 (4 items) | RSS
