Universal (non b&o remote) to control b&o and other brands
This post has 10 Replies | 3 Followers
Ronnie
Milton Keynes, UK
Posts 110
Ronnie Posted: Sat, Jun 9 2012 3:21 AM
Hello there,
I was wondering if anyone knows a non b&o universal remote that would be able to control my b&o system (avant and ouverture etc) and my projector, sky box, wii, ps3 etc?
I have been looking around and like the sounds of the remotes philips offer with macro functions like watch tv or watch movie or listen to  cd but am unsure that it would support b&o too.
Your help will be much appreciated!
miniac
Posts 9
miniac replied on Sat, Jun 9 2012 7:18 AM
before I got the beo6 I had a Logitech Harmony One. Can control everything you mentioned including macros and the olufsen stuff and is way easier to program than the beo6.
Except that the Harmony is made of plastic I really loved it.
Stoobietoo
Exeter, Devon, UK
Posts 692
Before getting my Beo5 I used (& still do) Philips Pronto remotes. They can all control B&O and have excellent macro functions, but you are looking at the same sort of money as a good used Beo5/6 with the same amount of programming needed for either the Beo5/6 or the Philips Pronto.
Your PS3 is not fully controlable by any standard universal IR remote without a separate little converter box. (an IR remote will control many functions but you need a Bluetooth box to switch on/off and some other functions I believe) .
The Harmony remotes that miniac suggests are really good too and do B&O, they do macros (called something like "activities" or something) but again you need the Bluetooth for your PS3. Here is a site that deals a lot with Harmony.
I also came across this some time ago and it looks really neat and not too plasticky. there is some feedback here from a guy who bought one. It seems to do simple macros too. ( a web search can find them at a fairly reasonable price)
Stoobie
kokomo
Spain
Posts 206
kokomo replied on Sat, Jun 9 2012 11:58 AM
I'm at this decision point now as I have B&O stuff including LC2s, but now sadly not a B&O TV. I've considered the Harmony 900 which is well regarded and well reviewed but I'm loath to say goodbye to my lovely BEO4 so I think it's the Lintronics route for me. I'm a bid daunted by the need to programme the Lintronics unit, but I'm fairly computer literate so I don't think it will be too big a problem. The Harmony needs programming via a PC also however.
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Sat, Jun 9 2012 12:37 PM
miniac:
Looks like I will be getting the harmony one, looks aren't bad, does everything i want it too, and can get it for just under £100. What a bargain.
I was just looking on the compatibility website and for some weird reason, it will do the avant, a beocenter 2300, but not the ouverture, it says the frequency is too high, which is strange, as the other b&o devices I have use the same frequency. But hey, if it wont work, i'l just programme the remote for the beocenter which should still control the ouverture anyway.
Thanks Very much for your help.
Ronnie
Milton Keynes, UK
Posts 110
miniac:
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Sat, Jun 9 2012 12:40 PM
Stoobietoo:
Stoobie
Ok, i think i'll just continue to use the ps3 controller to use the ps3.
Thanks for your help.
Stoobietoo
Exeter, Devon, UK
Posts 692
Ronnie:
Or  get one of these if you go for the Harmony.
Stoobie
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Sat, Jun 9 2012 3:45 PM
Stoobietoo:
Ronnie:
Stoobie
Nice! Thanks!
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Jun 9 2012 6:56 PM
Ditto on the Logitech Harmony One. I did have to go back and forth with their tech support trying different files they prepared to finally get functionality but eventually did and they were very helpful. I still use it for my non B&O Video setup.
Jeff
miniac
Posts 9
miniac replied on Sun, Jun 10 2012 9:05 AM
I used the harmony with an Ouverture - and there was absolutely no problem.
Page 1 of 1 (11 items) | RSS
