How to open a Beo5/6
Alias
Posts 11
Alias Posted: Sun, Jun 10 2012 7:54 AM
Hi
My Beo6 doesn't work anymore. I have no idea why but I think it is the touchscreen. The red light in the back works so it cannot be the battery.
Does anybody know how to open a Beo6? Do I need a special tool for that?
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Jun 10 2012 8:48 AM
Isn't a Beo6 less than a year old, and thus under warranty? Leave it alone and take it to your dealer.
With no available documentation, there's likely nothing one could do to help it anyway.
--mika
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
As stated, your Beo6 is under warranty and therefore you should return it to your dealer for replacement or repair.
Even if you were to open the unit, there is no way you could repair this product.
The screen also holds the electronics of the unit and would be replaced by your dealer as a whole, see photo
Regards Keith....
Bart
Netherlands
Posts 5
Bart replied on Fri, Jun 15 2012 9:37 AM
Hi Keith,
I have a Beo5 (which is not under warranty anymore) that has a bit of a loose connection between the bottom and the touchscreen. When I touch the screen it moves a bit which is not the real B&O feeling... Do you know how I can repair this?
Regards, Bart
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
