Beosound 5 Encore cannot see my Synology NAS
Strauss Sun
USA
Posts 30
Strauss Sun Posted: Wed, May 13 2015 3:42 PM
I recently got a Synology NAS ( DS215j).  And I put my digital music (FLAC format) under the shared folder ' music'.   When I connect BS5E to the local network, it cannot see the NAS.
I installed the media server in NAS and activated the UPnP/DLNA function.   The BS5E is on the device list but BS5E is not able to browse the music on the NAS.
I even tried to connect both your NAS and BeoSound 5 Encore to the router via cable, they were not able to see each other either.
Has anyone ever experienced the same problem ?  Any suggestion is welcome !
beopiranha
Germany
Posts 125
Twonky Server is a perfect solution. I'm using twonky server on my NAS with BS5 since 2011. Never had problems, very stable...
You just have to learn how to do. It sounds complicated but not!
Beovision Avant 55 / BV 11-40 / BV7-40 / Beovision Avant / Beosound 9000 / Beosound 5 Encore / Beosystem 4500 / Beosystem 6500 / Beocenter 9000 / Beolab 5000 / Beolab 18 / Beolab 19 / Beolab 11 / Beolab 17 / 3 sets of Beolab 4000 / Beovox Red Line 60.2
mbee
Paris, France
Posts 1,842
mbee replied on Wed, May 13 2015 8:42 PM
Twonky is really inferior to the DS media station...
Stupid question: when you go to package center, what is the status of Media server? It should be "running"...
beopiranha
Germany
Posts 125
mbee, why do you think that Twonky is an inferior solution for DS? As I wrote in my previous post I never had any problem with it. Or put it on different way, what would be your suggestion and why?
mbee
Paris, France
Posts 1,842
mbee replied on Wed, May 13 2015 9:41 PM
DS is allo stable, I've used it for years without any problem with the Encore.
I say it's inferior because i was using it with my previous NAS and it's just night and day : you can configure everything with DS, you can stream to your iPhone with real time re encoding if needed, you can do a lot of advanced stuff where Twonky is just a DLNA server that works a bit basically.
compare the two and you will never go back to Twonky !
Strauss Sun
USA
Posts 30
I finally get it done ! Now it works !
I made a mistake that I thought BS5E will recoginze NAS automatically when you connect both to the same local network. In fact, you have to do some settings in the BS5E then the NAS will be seen.
Thanks for your everybody's input and help !
Sal
California, USA
Posts 1,197
Sal replied on Thu, May 14 2015 3:44 PM
mbee:
I'm currently using Twonky because it's free and basic, but like you, I've been a bit disappointed that I can't configure the heck out of it easily. For a while now, I've actually been considering a Synology NAS, can you describe how configurable the media server portion of the NAS is in terms of a comparison with Twonky?
Currently, I've been running a Drobo 5N flawlessly for years, but a family member got a Synology last year and swears by it, and I have to admit, it is a compelling device.
Thanks!
CB
> You are Here <
Posts 1,762
CB replied on Thu, May 14 2015 4:33 PM
brg3466:
I have a similar issue with my Synology DS115j and my Beosound Essence Sad
Two server are present in DS Audio : Diskstation and TwonkyServer.
The Twonky server is empty, but the Essence sees it on the network, and cannot see my Diskstation.
Any idea how to solve this?
Strauss Sun
USA
Posts 30
It is quite easy to run Synology. You go to the package centre and install the media server. And immediately, you can see BS5E is appeared in the DLNA list.
It is a bit tricky in BS5E on the other side. You have to follow the manual carefully in order to make your BS5E see the NAS.
Page 1 of 1 (9 items) | RSS
