Dear All,
Just purchased a B&O remote ONE on the basis that it will control legacy B&O products if you switch it to the beo4 mode ( so that it mimics beo 4 commands)
I have a beovision 4 which it controls perfectly and a beo centre 2.
It will switch and control the beovision perfectly, and the radio but it will only switch on the BC2 and the arrow buttons are not operable ( even pressing go before ect) and yet it all works perfecty with beo 4!!
Any experts in that can help!!
Regards
when putting the BeoRemote 1 into Beo4 mode the "arrow buttons" are the same as the navigation joystick of the latest Beo4.
Did you try the P+/P- and the WIND buttons instead? Those should execute the "arrow button" commands of Beo4.
BR,BeoMotion.
Hi there
Thank you for your reply
None of the arrow buttons work and it will not control beocentre 2 other than switch it on!! P+/P unresponsive and the WIND so one cannot move the tracks or start the DVD
There are 4 different Beo4 compatibility modes.Which one did you choose?Did you also try the "BeoSound" mode?
Hi I tried all the modes my beo 4 works perfectly the REMOTE ONE does not.
Very frustrating that the backwards compatability seems not to exists althoygh B&O says it does!!
Strange.Even official B&O documents say that it should be possible with the P+/P- and WIND buttons...See here: LINK
The problem is that you cannot move through the tracks on a DVD this is no where near close to what a beo4/5 can do- B&O should revise the information so individuals don't buy this product in error!
BeoMotion:Strange. Even official B&O documents say that it should be possible with the P+/P- and WIND buttons... See here: LINK
Raeuber:If you try to use Beo4 with navi button with Beocenter 2 (or many other older products) you will have the same problems as with BR One
I cannot confirm this. I can use a NAV-Beo4 in mode 1 to skip between track even on older systems. There is no difference in IR signals between the outer arrow keys.
BeoMotion:I cannot confirm this. I can use a NAV-Beo4 in mode 1 to skip between track even on older systems. There is no difference in IR signals between the outer arrow keys.Hi,when putting the BeoRemote 1 into Beo4 mode the "arrow buttons" are the same as the navigation joystick of the latest Beo4.Did you try the P+/P- and the WIND buttons instead? Those should execute the "arrow button" commands of Beo4.
Raeuber:Why doesn't your hint work with BC2?? There must be a difference in IR signals!
I just checked that again.
NAV Beo4 in mode 1 (nav enabled) can definitively skip and change tracks with the arrow keys on an old BeoSystem 2500.In the next days I will try the same with a BR1 just to be sure.
I don't know why he has got those problems with his BC2. Maybe there is something other wrong...
@355f: Can you explain whether and how BV4 and BC2 are connected and set up?
BeoMotion:I just checked that again.NAV Beo4 in mode 1 (nav enabled) can definitively skip and change tracks with the arrow keys on an old BeoSystem 2500. In the next days I will try the same with a BR1 just to be sure.I don't know why he has got those problems with his BC2. Maybe there is something other wrong...@ 355f : Can you explain whether and how BV4 and BC2 are connected and set up?
BeoSound 4 test (not at the latest firmware level) playing A-MEM (SD Card)
>>| skips between "playlists" / folders
P+ skips tracks within a given "playlist" / folder
BeoNut since '75
Whichever beo 4 'option' one uses in the remote one it wil not operate a BC2 beyond the following.
\you can switch on the DVD as the 'my buttons' become like beo 4. You can use the play and pause but you cannot use any navigation. So there is no way I can advance a track ect.
Whilst I appreciate that this product is mainly for new products- very disappointing that B&O gives out useless information regarding its compatability.
So, with the possible though of an 'upgrade' have a demo of the avant 55.
Summary, in UHD it looks as good as any sony I have seen priced at a 10th or the price, on HD the picture is more dithering that my BV4 with beo system 3 and on SD it is positively the WORST picture ive seen in a long time.- that's progress I suppose
