Running single speaker on Beomaster 5000
This post has 3 Replies | 0 Followers
Don Oser
Lafayette,Louisiana. U.S.
Posts 50
Don Oser Posted: Fri, May 22 2015 5:52 PM
so my question is...would I do any damage to the unused channel if I only run one S80.2 speaker. If it's ok then do I adjust balance all the way to ch. with speaker. I only have one speaker at this time and very much want to use this system. Thanks
tournedos
Finland
Posts 7,357
tournedos replied on Fri, May 22 2015 6:25 PM
No problem at all, and you don't need to bother with the balance setting either.
--mika
Peter
Earsdon
Posts 11,991
Peter replied on Fri, May 22 2015 6:54 PM
You will of course only get one channel - if listening to the radio, this is not an issue as you can set it to FM Mono but using other sources will deprive you of one channel so will sound a bit odd!
Peter
Don Oser
Posts 50
Don Oser replied on Sat, May 23 2015 12:43 AM
Thanks Peter & tournedos. I was listening to RUSH last night and it sounded so GOOD! I'm so bummed out about the missing speaker. I can only imagine how good it will sound with both speakers. Still hopeful that it will turn up.
Page 1 of 1 (4 items) | RSS
