Beocenter 9500
This post has 4 Replies | 0 Followers
mayface
Posts 37
mayface Posted: Mon, Jun 11 2012 8:58 PM
Can someone advise me on the thickness of double sided foam tape i need to buy to re glue the glass panels on a 9500. The company i normally use for tape have offered me 6mm wide tape in either 1mm, 2mm or 3mm thickness (depth).
Any advice would be much appreciated.
Regards,
Darren
kallasr
Germany
Posts 2,562
kallasr replied on Mon, Jun 11 2012 9:03 PM
Search eBay.co.uk there is beocenter per cut glass tape available....
Ralf
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Jun 11 2012 9:11 PM
I took advice from the old forum and simply used superglue gel - the gel is less messy than normal superglue.  I left the old tape in situ and saved myself a lot of time in tape removal/cleaning.  I did 2 BC9500s a couple of years ago and have had no problems.
Medogsfat
Leeds West Yorkshire
Posts 3,896
Medogsfat replied on Mon, Jun 11 2012 9:23 PM
1mm thick & 6mm wide.
Where are you located? I have some spare if you want it?
Chris.
mayface
Posts 37
mayface replied on Mon, Jun 11 2012 9:55 PM
Thanks for all you replies and thanks for the offer and description of the tape Chris. I'll order some 1 mm tape tomorrow - it will be handy to have a full roll in case i screw up but thanks for the offer Chris.
Regards,
Darren
Page 1 of 1 (5 items) | RSS
