Hi, I need some help.
I recently inherited a Beolab 5000 and a CDX compact disk player.
The left hinge on the cdx lid has broken and shows some signs of a previous repair.
I've seen and understand the hinge repair in the archive and have downloaded the service manual, but for the life of me I can't see how I would get the hinge out to repair it and the put it back.
I'm determined that it will be put to use with the amplifier and would appreciate any advice, or at a last resort if there is anyone who repairs these cd players?
I've attached some pictures with comments on them.
The pin is fixed, it is pressure set. You have to remove the whole left mechanism - easy enough.
Jacques
Good Evening Jaques.
I have removed the hinge & repaired it following the advice by another member but an having trouble combining the hinge with the mechanism.Can you help please?
Regards,
Julian
Good Evening,
Having found a manual on line I managed to in stall the hinge.The CDX now operates & plays perfectly.
How did you repair the hinge. Mine is broken on the same way.
Ask at Beoparts-shop.
Good Afternoon,
There is an article within the Archive forum that shows how to do this.
https://archivedarchivedforum2.beoworld.org/forums/t/14522.aspx posted by medogsfat.
It works a treat and is quite easy to do.
Dillen: Ask at Beoparts-shop. Martin
Wow, great 👍🏻 Well done ☺️
Available here:
Left hinge for Beogram CDX CDX2 CD3300 Top Lid – Beoparts-shop
Having repaired the hinge on my CDX there is no pin only a hole for one to sit in.
Julimart: Good Evening, Having repaired the hinge on my CDX there is no pin only a hole for one to sit in. Regards, Julian
Eh... yes, - and I'm not sure what you mean?
