Hello all
I have decided to go ahead and buy the beosound moment because it will give me everything I have today but in a more intergrated way.
I have a complete ML setup with a audio and video master, both are in separate rooms both with their own speakers connected. I understand that with the NL/ML convertor I can interface the two networks but in a limited fasion. My BLGW can see the current audio master Beosound 4 but pretty much see's it has the TV as an AV master.
I have learnt that I am going to need the below items.
my assumptions are below with some thougths if any are wrong or can be done better please let me know.
My TV is in the main room with speakers connected.currently I have a Audio Master in my music listening room with speakers connected.I understand when a moment is conncted via a NL/ML convertor it will behave is if the sources are coming from the TV so no speakers can be connected to it.this means by Moment will sit quite happily only sending music over ethernet to the NL/ML convertor.
I also understand that the NL/ML convertor can act as an Beolink active which will allow me to connect my Penta 3 speakers to it then acting like a link room and a converor with IR connected. I am told that my Penta's will still be able to display the source A.AUX etc if conencted to the NL/ML convertor.
this should solve the problem of the not being able to connect speakers to my tv and moment.
When i look at NL/ML convertor setup in the moment setup guide it says sat it up as a A Master or an AV Master.
I have a setup example document in front of me that says that you can only connect speakers to a convetor if it in an Audio slave role mode.
I am not sure but i think i might have a problem with this setup.
Basically I would love to have the moment in one room and the beovision 7 in another both with speakers connected but im not sure it works this way so i would have to have the convertor also act like an active which might not be possible with the option settings shown.
This coupled with i have the essance remote in Light mode that my setup picks up and the BLGW receives the commands and runs some macro's that active lighting etc i am not sure if the moment will be able to pass light commands back to the BLGW
Confused...........
Eclipse 65V1-32Beosound M5Essence MK2BLI
Hi there
after allot of reading and looking at Beroli's post I think my NL/ML convertor will be better off being in AMaster mode rather than AVMaster mode.
i have a big question as the paper I have shows you can only use the convertor as a active link also if it is in audio slave mode.
if the convetor is in AMASTER mode will it work with connected speakers or will I need a separate beolink active?
any thoughts?
Alternative.
Setup the Moment as described in the manual (NL/ML converter as AMaster)
Use the BS4 as local source in a linkroom (option 6; with speakers connected)
Then one can use the Moment as source from the main room and the BS4 locally. And you still have two seperate rooms with speakers.
Also a Delay-box isn't nessessary in this setup
