Connect BV11and Ouverture to BL 8000 speakers
LesGosling
Posts 1
LesGosling Posted: Sun, May 31 2015 10:53 PM
I have my BV 11 connected to BL8000/6000 speakers. Additionally I want to connect a BG 6500 deck to the same same 8000 speakers. My plan is to connect the deck via my old Ouverture. I don't think I can connect the Ouverture to the BV 11, therefore how can I connect two power link sources to the same 8000 speakers?
Andrew
Frinton, UK
Posts 917
Andrew replied on Mon, Jun 1 2015 9:21 AM
I think this has been mentioned before and was ruled out - you need to connect your beogram to the overture and get a ML converter and leads to connect the overture to the TV so that it all works as one system
Amazone
Netherlands
Posts 187
Amazone replied on Mon, Jun 1 2015 10:04 AM
Or simply something like an almando powerlink switch, if it's just these devices
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Page 1 of 1 (3 items) | RSS
