I have my BV 11 connected to BL8000/6000 speakers. Additionally I want to connect a BG 6500 deck to the same same 8000 speakers. My plan is to connect the deck via my old Ouverture. I don't think I can connect the Ouverture to the BV 11, therefore how can I connect two power link sources to the same 8000 speakers?
I think this has been mentioned before and was ruled out - you need to connect your beogram to the overture and get a ML converter and leads to connect the overture to the TV so that it all works as one system
Or simply something like an almando powerlink switch, if it's just these devices
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
