I have been working on my new to me Beocenter 7700. After ordering parts and building some speaker cables, I was pleased to find out that everything but the tape deck worked perfectly. While cleaning the inside and changing the tape belts, I decided to pull off the plastic cover for the line in/out, which contains 4 prongs on a DIN plug. I have since discovered that this same piece acts as a bridge between the preamp and the main amp. Afterwards, of course, I had lost sound. However, even if I replace the 4 prong DIN plug, there is no sound. Absolute quiet, not a pop or a click or anything to indicate it works.
I feel like there is something simple I am overlooking to return the unit to function. Of course, I checked cables, power, mute and speaker switches, and all the simple things that can be overlooked that would cause a similar problem. Any ideas?
I could post a picture of the connections, but essentially all connections are the speaker cables and the 4 prong DIN bridge piece. is there anything else I could try? Are there some connections I am overlooking?
Thanks.
Joe
You didn't forget the internal speaker connections, did you?Or one or both speaker switches?
