- Flere
smile and enjoy the moment
That will be part of the expected 'multiroom update'.
At the moment it is not quite sure, when this will be rolled out - probably in august?
Watch out for the message on the Avant screen and/or read what will be discussed on Beoworld.
This functionality is already included in the TV software for some time now.
I think that only the BeoMusic app needs an update to make this working with the TVs.
You are right - that is the better way of explaining it
Anyway - we are still waiting for the update.
Millemissen:You are right - that is the better way of explaining it
Not to confuse with the general Homemedia source. One part of the BeoMusic "server backend" was silently included with a SW update some time ago.
Otherweise we would not be able to 'share speakers' between two connected NL-BV's - as we already can.
So multiroom is already there - it is just the question: which products support it, and how to control it (from the BeoMusic app).
We will soon be wiser.
There is even room for more products
interesting times ahead then :-)
i didn't know anything about this... proof will be in the pudding
... Hold on MM.
I'm now confused.
When i install the BeoMusic app on my phone it says that it cannot find a product.
I have the Avant and no other device.
How do i get to use it?
Millemissen:There is even room for more products MM There is a tv - and there is a BV.
Aussie Michael: When i install the BeoMusic app on my phone it says that it cannot find a product. I have the Avant and no other device. How do i get to use it?
The BeoMusic <-> TV function wasn't released yet and is only a rumor at the moment.
Aussie Michael: ... Hold on MM. I'm now confused. When i install the BeoMusic app on my phone it says that it cannot find a product. I have the Avant and no other device. How do i get to use it? Thanks :-)
You don't - yet!
And to do multiroom, you'll need 'multi' of products
haha - but i want it from one product! :-)
I'd like to use the BeoMusic app with the speakers connected to my BV Avant :-)
Why not use the BeoRemote app for that?
yes but id like without my avant on
the only option i have there is the Avant and no other products like my Lab 3s although they are connected to wireless receiver 1s
Anyway.. i'll just wait
Millemissen: There is even room for more products MM
Actually the lay out (UI) has been changed in the beta version of the Music app
Aussie Michael: yes but id like without my avant on the only option i have there is the Avant and no other products like my Lab 3s although they are connected to wireless receiver 1s Anyway.. i'll just wait
I'm pretty much sure that this will be possible.
BeoMotion:I'm pretty much sure that this will be possible.
any more news on this?
This never came to be right? BeoMusic still doesn't work with the TVs
Startet playing from the Essence, then 'joined in' using the BeoMusic app - the V1 turned on from standby.
'Joining out' of the V1 with the app turns the tv off again.
But maybe you are expecting, that the sources of the tv should be visible (and manageable) in the app as well?
Which sources would you expect to appear there, then?
Can you share TV sound (football game, Tv show...) on another NL multiroom product? So if you're in another room and you can't watch it at the moment you can at least listen to TV's audio?
Yes you can AnalogPlanet
Thanks for the confirmation.
That means I can put my A9 below the TV and use it as a powerful centre speaker. <3 That is really cool, and unique to B&O.
Will probably be hard to find the right balance between the speakers of the tv and the A9.
But will be possible to use it so, yes.
P.S. The A9 will never be able to act like a 'center speaker', since it (after all) is a stereo speaker.
That depends on the connection.
If you hardwire, it should be ok.
But it would be much easier to use the Line-in of the A9 (from a PL-out of rhe tv), create a Speaker Group including or exclusively the A9 and use that.
steve1977: with line-in, it would obviously work, but don't know whether the avant can output to line-in and PL in parallel?
Of course - you can make your Speaker Groups as you please.
In that case you would have to control the volume of the A9 manually and seperately.
Honestly - personally I would not think of combining both --- it is too much fuss...
...and B&O is about avoiding fuss and keep things simple.
