Beovision Avant and Beo Music app
This post has 29 Replies | 1 Follower
Flere
Netherlands
Posts 345
Flere Posted: Sun, Jun 14 2015 11:16 PM
I heard somewhere that the Avant would be extended to support the Beo Music app.
Any idea when this will be available?
- Flere
smile and enjoy the moment
Millemissen
Flensborg, Denmark
Posts 14,680
That will be part of the expected 'multiroom update'.
At the moment it is not quite sure, when this will be rolled out - probably in august?
Watch out for the message on the Avant screen and/or read what will be discussed on Beoworld.
BeoMotion
Posts 384
BeoMotion replied on Mon, Jun 15 2015 9:00 AM
This functionality is already included in the TV software for some time now.
I think that only the BeoMusic app needs an update to make this working with the TVs.
Millemissen
Flensborg, Denmark
Posts 14,680
You are right - that is the better way of explaining it Yes - thumbs up
Anyway - we are still waiting for the update.
BeoMotion
Posts 384
BeoMotion replied on Mon, Jun 15 2015 9:17 AM
Millemissen:
Not to confuse with the general Homemedia source. One part of the BeoMusic "server backend" was silently included with a SW update some time ago.
Millemissen
Flensborg, Denmark
Posts 14,680
Otherweise we would not be able to 'share speakers' between two connected NL-BV's - as we already can.
So multiroom is already there - it is just the question: which products support it, and how to control it (from the BeoMusic app).
We will soon be wiser.
Millemissen
Flensborg, Denmark
Posts 14,680
There is even room for more products Big Smile
Aussie Michael
Melbourne, AU
Posts 3,730
interesting times ahead then :-)
i didn't know anything about this... proof will be in the pudding
Aussie Michael
Melbourne, AU
Posts 3,730
... Hold on MM.
I'm now confused.
When i install the BeoMusic app on my phone it says that it cannot find a product.
I have the Avant and no other device.
How do i get to use it?
Chris Townsend
Qatar
Posts 3,531
Millemissen:
So maybe the new speaker is a link speaker!
BeoMotion
Posts 384
BeoMotion replied on Mon, Jun 15 2015 11:48 AM
Aussie Michael:
The BeoMusic <-> TV function wasn't released yet and is only a rumor at the moment.
Millemissen
Flensborg, Denmark
Posts 14,680
Aussie Michael:
... Hold on MM.
I'm now confused.
You don't - yet!
And to do multiroom, you'll need 'multi' of products Stick out tongue
Aussie Michael
Melbourne, AU
Posts 3,730
haha - but i want it from one product! :-)
I'd like to use the BeoMusic app with the speakers connected to my BV Avant :-)
Millemissen
Flensborg, Denmark
Posts 14,680
Why not use the BeoRemote app for that?
Aussie Michael
Melbourne, AU
Posts 3,730
yes but id like without my avant on
the only option i have there is the Avant and no other products like my Lab 3s although they are connected to wireless receiver 1s
Anyway.. i'll just wait
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Jun 15 2015 1:08 PM
Millemissen:
Actually the lay out (UI) has been changed in the beta version of the Music app
BeoMotion
Posts 384
BeoMotion replied on Mon, Jun 15 2015 1:11 PM
Aussie Michael:
I'm pretty much sure that this will be possible.
Aussie Michael
Melbourne, AU
Posts 3,730
BeoMotion:
Lets have a Party !!!
Alex
Essex
Posts 64
Alex replied on Mon, Aug 17 2015 8:25 PM
any more news on this?
lundmark
Stockholm, Sweden
Posts 105
This never came to be right? BeoMusic still doesn't work with the TVs
Millemissen
Flensborg, Denmark
Posts 14,680
Startet playing from the Essence, then 'joined in' using the BeoMusic app - the V1 turned on from standby.
'Joining out' of the V1 with the app turns the tv off again.
But maybe you are expecting, that the sources of the tv should be visible (and manageable) in the app as well?
Which sources would you expect to appear there, then?
AnalogPlanet
Vienna, Austria
Posts 678
Can you share TV sound (football game, Tv show...) on another NL multiroom product? So if you're in another room and you can't watch it at the moment you can at least listen to TV's audio?
Aussie Michael
Melbourne, AU
Posts 3,730
Yes you can AnalogPlanet
AnalogPlanet
Vienna, Austria
Posts 678
Thanks for the confirmation.
That means I can put my A9 below the TV and use it as a powerful centre speaker. <3 That is really cool, and unique to B&O.
Aussie Michael
Melbourne, AU
Posts 3,730
Yes
For example my avant is on and when I tap the a9 it joins the "ongoing sound experience"
The TV obviously in this scenario is an NL product and so is the a9
The a9 also has line in
Millemissen
Flensborg, Denmark
Posts 14,680
Will probably be hard to find the right balance between the speakers of the tv and the A9.
But will be possible to use it so, yes.
P.S. The A9 will never be able to act like a 'center speaker', since it (after all) is a stereo speaker.
steve1977
Posts 911
steve1977 replied on Wed, Sep 7 2016 12:43 PM
are you guys sure this will work? I doubt it and it doesn't work if you try to do this via an A9.
I would anticipate that the video/audio or the audio/audio goes out of sync?
Millemissen
Flensborg, Denmark
Posts 14,680
That depends on the connection.
If you hardwire, it should be ok.
But it would be much easier to use the Line-in of the A9 (from a PL-out of rhe tv), create a Speaker Group including or exclusively the A9 and use that.
steve1977
Posts 911
I thought the issue is not only the wire, but decoding. for the described purpose, even a delay of 1/20 of a second would be hearable.
the avant will output to the speakers, which happens instantly (and in sync). if you broadcast to an A9 via NL, I'd assume that it can technically not be in sync.
with line-in, it would obviously work, but don't know whether the avant can output to line-in and PL in parallel?
Millemissen
Flensborg, Denmark
Posts 14,680
steve1977:
Of course - you can make your Speaker Groups as you please.
In that case you would have to control the volume of the A9 manually and seperately.
Honestly - personally I would not think of combining both --- it is too much fuss...
...and B&O is about avoiding fuss and keep things simple.
Page 1 of 1 (30 items) | RSS
