Eclipse 65V1-32Beosound M5Essence MK2BLI
I have problems with the remote access. I use a khimo account to enter with the beolink app the blgw.
Sometimes no icons of the room
No access to the custom stings
No access the the nest thermostat (you can see only the home/away button)
If you want to control something, the app is crashing
Newest app, ios an blgwv1.3.0.
Local over the wifi an remote access via port forwarding - everything worked fine!
Normal 0 21 false false false DE JA X-NONE
beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Getting an account through Khimo is very confusing. You must first request an account from the BLGW setup screen as an "installer." Then, you must go to the Khimo site as an "installer" to then invite YOURSELF to get an account as a homeowner. Note that the account indicates that it is only free for a 30 day trial. After that, you must pay $120 USD a year. B&O really should be clear about that when they are promoting the IFTTT feature.
hi! you must use the khimo link in the blgw software!
but with khimo remote access, at home wifi everything works with the beolink app like normal. but outside the wifi and via the kimo account the beolink app crashed if i press a button in the app. (tv for example) also i can see sometimes no roomicons. i can not see the temperature buttons of the nest thermostat outside the wifi. (only the home/away button), sometime there is the complete scene button missing.
now i use port forwarding and save money. not so save but it works well.
port forwarding ist not that save as the khimo solution. (an no ifttt!)
you need a fix external ip. (and a strong password!)
forward port to the ip of the blgw:
9100
23 (telnet)
9000 (blgw protocol)
80 (web panel)
