Beolink NL/ML and spotify
This post has 10 Replies | 1 Follower
doun
Posts 25
doun Posted: Thu, Jul 2 2015 1:44 PM
Hello,
I have a Beovision 11 and a Beolink NL/ML. A BeoLink passive is connected to the Beolink NL/ML. I want to listen to the Spotify sound through the BeoLink passive. Spotify is connected to the CD input in the Beovision 11. How to configure the Beolink NL/ML because I am not able to setup my equipement?
However, I am able to listen to the sound of my AppleTV(DTV2) but not Spotify.
Any idea?
Didier
BeoMotion
Posts 384
Due to licensing restrictions B&O is not allowed to distribute the Spotify source digitally. (BV11 <-> NL/ML Converter is a digital connection)
So what you want to do is not possible.
BR,
BeoMotion.
StUrrock
Posts 995
Take one of the PL outputs from the TV to the line in of the NL/ML converter if the TV is on you will be able to hear the sound elsewhere, but not in sync.
Millemissen
Flensborg, Denmark
Posts 14,680
Other possibilies:
1: Connect a Playmaker or a BS Essence to the line-in of the converter.
Playmaker - airplay Spotify ------ Essence - use built-in Spotify Connect.
2: Connect a 'Gramofon' to the line-in of the converter.
This way you will be able to use Spotify/Spotify Connect everywhere on your (B&O) network.
For the device/Gramofon search the web and/or see my thread 'Got me a new Gramofon' here:
http://thearchivedforum2.beoworld.org/forums/t/13002.aspx
doun
Posts 25
doun replied on Thu, Jul 2 2015 4:16 PM
Hello,
Thanks for your useful answers. Again a limitation of the system....Sad
Millemissen
Flensborg, Denmark
Posts 14,680
doun:
Hello,
No - that is a limitation of Spotify!
mjmedlo
Posts 922
mjmedlo replied on Thu, Jul 2 2015 4:34 PM
Millemissen:
Correct. All about licensing and digital distribution.
I use AirPlay in to a bs5 and distribute over the network.
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Jul 2 2015 4:43 PM
Millemissen:
That's why I guess Spotify Connect will be sorted out on Besound Essence 2nd gen. B&O will only use Deezer because of allowed digital sound distribution. I hope for B&O Deezer will survive because Spotify is already very strong and Apple Music will also be very successful.
Räuber
StUrrock
Posts 995
Millemissen:
Other possibilies:
lovin it Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Raeuber:
Not according to what I have heard!
You will be able to distribute Spotify Connect, BUT only to other devices on the NL-network, that supports Spotify Connect (e.g. from an Essence (2) to an A9 (2)). But only as 'partymode - not two different streams at the same time in the network.
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Jul 2 2015 8:35 PM
Millemissen:
Thanks MM, that would be reasonable.
Räuber
Page 1 of 1 (11 items) | RSS
