Hello,
I have a Beovision 11 and a Beolink NL/ML. A BeoLink passive is connected to the Beolink NL/ML. I want to listen to the Spotify sound through the BeoLink passive. Spotify is connected to the CD input in the Beovision 11. How to configure the Beolink NL/ML because I am not able to setup my equipement?
However, I am able to listen to the sound of my AppleTV(DTV2) but not Spotify.
Any idea?
Didier
Due to licensing restrictions B&O is not allowed to distribute the Spotify source digitally. (BV11 <-> NL/ML Converter is a digital connection)So what you want to do is not possible.
BR,BeoMotion.
Take one of the PL outputs from the TV to the line in of the NL/ML converter if the TV is on you will be able to hear the sound elsewhere, but not in sync.
Other possibilies:
1: Connect a Playmaker or a BS Essence to the line-in of the converter.
Playmaker - airplay Spotify ------ Essence - use built-in Spotify Connect.
2: Connect a 'Gramofon' to the line-in of the converter.
This way you will be able to use Spotify/Spotify Connect everywhere on your (B&O) network.
For the device/Gramofon search the web and/or see my thread 'Got me a new Gramofon' here:
http://thearchivedforum2.beoworld.org/forums/t/13002.aspx
Thanks for your useful answers. Again a limitation of the system....
doun: Hello, Thanks for your useful answers. Again a limitation of the system....
No - that is a limitation of Spotify!
Millemissen:No - that is a limitation of Spotify! MM There is a tv - and there is a BV.
Millemissen:Other possibilies: 1: Connect a Playmaker or a BS Essence to the line-in of the converter. Playmaker - airplay Spotify ------ Essence - use built-in Spotify Connect. 2: Connect a 'Gramofon' to the line-in of the converter. This way you will be able to use Spotify/Spotify Connect everywhere on your (B&O) network. For the device/Gramofon search the web and/or see my thread 'Got me a new Gramofon' here: http://thearchivedforum2.beoworld.org/forums/t/13002.aspx MM There is a tv - and there is a BV.
Raeuber: That's why I guess Spotify Connect will be sorted out on Besound Essence 2nd gen. B&O will only use Deezer because of allowed digital sound distribution.
Not according to what I have heard!
You will be able to distribute Spotify Connect, BUT only to other devices on the NL-network, that supports Spotify Connect (e.g. from an Essence (2) to an A9 (2)). But only as 'partymode - not two different streams at the same time in the network.
Millemissen:Not according to what I have heard! You will be able to distribute Spotify Connect, BUT only to other devices on the NL-network, that supports Spotify Connect (e.g. from an Essence (2) to an A9 (2)). But only as 'partymode - not two different streams at the same time in the network. MM There is a tv - and there is a BV.
