I'm having no luck connecting my MacBook Pro to my BV 8 40.
I connect the HDMI cable to socket B.
Using AV3 (the only connection offering PC) I select socket B and save.
And absolutely nothing.
Where am I going wrong?
Thanks for any help.
piers:I'm having no luck connecting my MacBook Pro to my BV 8 40. I connect the HDMI cable to socket B. Using AV3 (the only connection offering PC) I select socket B and save. And absolutely nothing. Where am I going wrong? Thanks for any help.
BeoNut since '75
Have you tried another HDMI cable? I've had faulty ones and a new one has worked fine.
Dave.
Hello Dave
Thanks for replying.
Yes, I've just tried another cable that I know for certain works but still nothing.
Piers
The BV8 probably expects an input on the VGA port, when you use AV3.
Did you confirm that the AV3 port should use the HDMI as the connection type?
Millemissen:The BV8 probably expects an input on the VGA port, when you use AV3. Did you confirm that the AV3 port should use the HDMI as the connection type? MM There is a tv - and there is a BV.
Thanks everyone for your help. I still haven't sorted out the problem but thanks anyway.
elephant: I think MM that you can see by my picture that AV3 is wiring with HDMI ON and VGA OFF
I did not see your picture, untill I already had posted my comment.
