Connecting BV 8 40 to MacBook Pro
piers
Posts 3
piers Posted: Fri, Jul 3 2015 1:24 AM
I'm having no luck connecting my MacBook Pro to my BV 8 40.
I connect the HDMI cable to socket B.
Using AV3 (the only connection offering PC) I select socket B and save.
And absolutely nothing.
Where am I going wrong?
Thanks for any help.
elephant
AU
Posts 8,219
piers:
Seems right from memory ... I will snap shot my configuration for you once I get home in a couple of hours
BeoNut since '75
Dave Farr
France
Posts 2,283
Have you tried another HDMI cable?  I've had faulty ones and a new one has worked fine.
Dave.
piers
Posts 3
piers replied on Fri, Jul 3 2015 10:48 AM
Hello Dave
Thanks for replying.
Yes, I've just tried another cable that I know for certain works but still nothing.
Piers
elephant
AU
Posts 8,219
elephant replied on Fri, Jul 3 2015 11:06 AM
Hope this helps ...
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
The BV8 probably expects an input on the VGA port, when you use AV3.
Did you confirm that the AV3 port should use the HDMI as the connection type?
elephant
AU
Posts 8,219
elephant replied on Sat, Jul 4 2015 12:30 AM
Millemissen:
I think MM that you can see by my picture that AV3 is wiring with HDMI ON and VGA OFF
Hopefully Piers has his VGA off ?
I wonder if there is a BV8-40 software level issue ...
BeoNut since '75
piers
Posts 3
piers replied on Sat, Jul 4 2015 8:39 PM
Thanks everyone for your help. I still haven't sorted out the problem but thanks anyway.
Piers
Millemissen
Flensborg, Denmark
Posts 14,680
elephant:
I did not see your picture, untill I already had posted my comment.
Page 1 of 1 (9 items) | RSS
DigiCert Secured Site Seal
