Macro for Volume Up
This post has 13 Replies | 1 Follower
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sun, Jul 5 2015 2:55 PM
Hello all
I want to create a Macro to turn the moment up with a wheel spin on the essence.
When i capture the commands into the gateway i have the below
Which is the one for volume to step up continually until i stop spinning the wheel
Time Description Action
2015-07-05 14:52:50 global/Global/SYSTEM/BLGW/STATE_UPDATE?revision=227! Add
2015-07-05 14:52:48 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:47 Home/Living Room/AV renderer/Beovision 7/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:47 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:47 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Press&Command=STEP_UP Add
2015-07-05 14:52:47 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:47 Home/Living Room/AV renderer/Beovision 7/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:47 Home/Living Room/AV renderer/Beovision 7/Light?Action=Press&Command=STEP_UP Add
2015-07-05 14:52:46 Home/Living Room/AV renderer/Beovision 7/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:46 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:46 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:46 Home/Living Room/AV renderer/Beovision 7/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:46 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Press&Command=STEP_UP Add
2015-07-05 14:52:46 Home/Living Room/AV renderer/Beovision 7/Light?Action=Press&Command=STEP_UP Add
2015-07-05 14:52:44 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:44 Home/Living Room/AV renderer/Beovision 7/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:43 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:42 Home/Living Room/AV renderer/Beovision 7/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:42 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Press&Command=STEP_UP Add
2015-07-05 14:52:42 Home/Living Room/AV renderer/Beovision 7/Light?Action=Press&Command=STEP_UP Add
2015-07-05 14:52:42 Home/Living Room/AV renderer/Beovision 7/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:41 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Key release&Command=STEP_UP Add
2015-07-05 14:52:40 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:40 Home/Living Room/AV renderer/Beovision 7/Light?Action=Continue&Command=STEP_UP Add
2015-07-05 14:52:40 Home/Music Room/AV renderer/BeoSound Moment 25012481/Light?Action=Press&Command=STEP_UP Add
2015-07-05 14:52:40 Home/Living Room/AV renderer/Beovision 7/Light?Action=Press&Command=STEP_UP Add
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
ok this command
causes a single step up in volume until i release and start again
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hi can anyone help with this I cannot get volume working apart from single steps with each twist.
I know it's the piece for multiple volume steps up.
Cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Tue, Jul 21 2015 2:40 AM
Seanie_230:
Cheers all
BLGW - Rekindling the love of ML
I've tried this too.
I couldn't make it work without continual turns as you're describing.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Aug 11 2015 9:13 PM
This is not directly an answer to your specific goal, but it's the answer that I got from Henrik, the creator of the MLGW/BLGW when I asked him about creating macros to control volume with continuous button presses using Lutron RadioRa 2 keypads. Henrik pointed out a very good point cautioning of the danger of creating macros for continuous volume increase in that there is a possibility that the "button release" macro might not get detected for whatever reason. In such a scenario, the volume increase could go out of control!
Here is the solution Henrik provided for me:
"Keeping the above in mind you could potentially implement it using the Scheduler in the old MLGW
Macro 1
Lutron press = Vol+ and start SchedulerA (a continuous scheduler)
Macro 2
SchedulerA = Vol+
Macro 3
Lutron release = Stop SchedulerA "
Chris Hassell
London
Posts 396
Hi chaps. I may have missed this in a more recent thread - but did anyone solve this or is it a variant of @beojeff's solution (although I guess the Essence Remote doesn't send a RELEASE command when you stop turning it)? Cheers, Chris
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Chris Hassell
London
Posts 396
Has anyone cracked a decent macro yet for the Essence remote controlling volume in IR mode(as smoothly as it does in BT mode)?
mjmedlo
Posts 922
mjmedlo replied on Sun, Dec 25 2016 12:32 AM
I have not
This is unfortunately a hard solve.
Chris Hassell
London
Posts 396
mjmedlo:
I have not
Darn it, as it would be great to use the other buttons for home control as well as music but the ring still makes most sense for volume.
Gordon38
Posts 3
Gordon38 replied on Sun, Jan 29 2017 6:23 PM
I'm curious how how others have set this up the work best possible way? Unsure
4 separate macros with Vol up + Vol down + Vol up-repeat + vol down-repeat?
Do you tick [Match CONTINUE..] in repeat-macro?
Any other tricks? Confused
Seanie_230
UK
Posts 2,278
Hello
From the Beta testing of the BLGW I understand that IR volume up by using a IR remote is not possible
The reason for this is that it's not reliable enough and the Essence remote will not provide a constant signal like the beofemotr one or beo4 does.
I had this same problem years ago when I used Lintronic it seems volume long presses have always been an issue
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Chris Hassell
London
Posts 396
Has anyone come up with anything for this yet? I might have a play this weekend as might be more possible with the more complex LUA coding available.
beojeff
USA
Posts 2,012
beojeff replied on Tue, May 2 2017 7:46 PM
Chris Hassell:
Beware. You could inadvertently discover just how loud your BeoLabs can get!
Chris Hassell
London
Posts 396
beojeff:
Been there ma friend! Might work on volume down first 😜
Page 1 of 1 (14 items) | RSS
