Hi
I am using a Beolink Active and amp to control my apple tv and feed sound to the speakers - problem i have is that A.Setup only appears if I select DVD - I cant seem to have it come up on the Beo4 if I have selected a video source - does anyone know how to configure the beo 4 so that it appears in both audio and video mode?
I just tried on three of my Beo4's (two of them with navi and with two different sw-versions).
it was not possible!
What are you trying to achieve?
Do you just want to adjust the startup sound level, bass etc once - or do you want to have access to adjust e.g bass, while you are listening?
Hi - it was so that I can have access to the bass and treble whilst listening on V.Mem - which controls the Apple TV - I cna switch from V.Mem to an audio source and change it but it would just be neater if it could be done in V.Mem
Hi Rauber
Thanks - I will try that tonight - fingers crossed - I read somewhere that you can move commands and customise the Beo4 - will definetely give that a go later.
Thanks again
@Räuber
Sehr gut :-)
Komisch - so weit hatte ich gar nicht gedacht :-(
@Andrew
Just grab the User Guide - you find the infos, that you need there.
Hi -had a look at the online manual but that didn't have what I wanted - I found the config guide for Beo 4 which gives what list functions are available against different sources and configuration for the various products. Anyway, seems A.Setup is not available under any of the Video Options - however V.Setup does give me access to bass and treble so all good. However I cannot see how to use the move function - but at least it's now doing what I want - thanks Rauber for pointing me in the right direction.
Move extra ‘buttons’
You can rearrange the order in which the extra ‘buttons’ appear when you press LIST.
> Press and hold the standby button down.
> Press LIST to get access to the Beo4 setup
function.
> Let go of both buttons. ADD? appears in the
display.
> Press LIST repeatedly to display MOVE? on
Beo4.
> Press GO to bring up the list of extra ‘buttons’.
The first ‘button’ appears in the display.
> Press or to move forwards or backwards
in the list of extra ’buttons’.
> Press GO to move and place the displayed
‘button’ as the first in the list, or ...
> ... press 1 – 9 to move the ‘button’ to a specific
position in the list.
> MOVED appears, indicating that the ‘button’
has been moved. You leave the Beo4 setup function automatically.
Older Beo4 versions (possibly pre-DVD button) don't have the MOVE function. If you have one of those and really need to have the entries in a certain order, you will first need to delete everything from the list and then add them again. At least I believe that changes the order - I never bothered to try in practice
--mika
Correct!
But the op stated, that he has one with the DVD button - otherweise he wouldn't be able to choose DVD.
That said - I am not sure, when the Move function actually was added.
