BeoNut since '75
5ghz wifi?
I would certainly hope for 802.11n 5GHz.
Also elephant, I think FLAC was actually supported already in first gen. Deezer would be very cool addition. :)
The moment is still on 2.4 and that doesnt work for streaming in my environment.
i dont want cable or extra boxes.
also am hoping that multiroom comes to beoplay devices soon,
i need them to be like sonos essentially.
It still seems very odd and sad that a product in the price range of the Essence and even the old Playmaker don't offer basic 5.0 GHz as well as 2.4 GHz. I have a ten dollar dongle for one laptop that does both, and quite well, and is not much larger than the USB plug part of it. This is not something cutting edge, it's all off the shelf, mature hardware.
Jeff
AnalogPlanet:I would certainly hope for 802.11n 5GHz. Also elephant, I think FLAC was actually supported already in first gen. Deezer would be very cool addition. :)
Raeuber:5 GHz would be important. But if Deezer comes I hope Spotify Connect will not be sorted out! Regards Räuber
elephant i swear you're the only one that receives calls from that store about new products.
You mention launch material - is this something you have a copy of.
May I also ask do the Australian stores do retail price lists anymore like they used to?
Aussie Michael:elephant i swear you're the only one that receives calls from that store about new products. You mention launch material - is this something you have a copy of. May I also ask do the Australian stores do retail price lists anymore like they used to?
elephant:That's two questions ! 1/ no and I only saw the summary, spec and multi room 2/ no and it's a pain whereas DK gives us a price list (via PeterPan) so it can't be too hard - and to answer the implied question ... I don't know if it's the same prices s previously ! BeoNut since '75
The Essence MK2 (box unit only) is listed in DK for 4995 DKK = 465 British Pound Sterlings = 670 € = 725 $ - as of June 2015.
What is that 4th device with the long hair? Very nice design
TWG:What is that 4th device with the long hair? Very nice design
BeoBoy68:Remote Control € 179.-IR sensor € 98.-
BeoBoy68:@ TWG Unfortunately, the 4th device is not to sell
Is there an unboxing somewhere ;-)))
elephant: I knew the IR would cost when it came ... but I did not spot that it was included in the announcement ! What functions are supported ? And which remotes (presuming its input and not PUC-like output) ?
For the functions with the ir-eye you will have to wait a bit - that is still a 'work in progress'.
The multi room, is that B&O own solution or just rebadged DLNA?
I read an interview, that they would extend it to Beoplay range. That could be nice.
What is 'rebadget DLNA'?
jk1002:The multi room, is that B&O own solution or just rebadged DLNA?
Communication between the NL BeoDevices is done via customized serverless XMPP messages.Audio is most likely distributed using the gstreamer framework.So no, it's not DLNA.
jk1002:The multi room, is that B&O own solution or just rebadged DLNA?I read an interview, that they would extend it to Beoplay range. That could be nice.
B&O multiroom is much more than DLNA.
Otherweise you would not be able to join in on or push sound to or from devices on the NL, and listen to multiple streams of Deezer etc....
elephant: To A9 ml 2 yes Sw updated V1 yes ? Others ???
To A9 ml 2 yes
Sw updated V1 yes ?
Others ???
To and from any NL-enbled tv, the BS Moment, the Essence (2nd gen), the speakers connected to the NL/ML Converter, the A9 (2nd Gen) and who knows what may come.....*
Note: not all sources are 'joinable' due to restrictions of the streaming services/streaming protocols.
* I would welcome a 'join-box' - a small NL-enabled device, to which you could connect any BL.
A small all-in-one speaker would be nice too.
elephant: TWG: What is that 4th device with the long hair? Very nice design I think you have designs on the device ... a terribly English joke I am afraid
@Elephant: Thank you, you just enhanced my language skills.
My dealer says delivery 18th August in the UK. The delivery date has been brought forward 2 weeks. Can confirm you are able to choose either a table top stand or a wall mount.
ahjrennie:My dealer says delivery 18th August in the UK. The delivery date has been brought forward 2 weeks. Can confirm you are able to choose either a table top stand or a wall mount.
Does anyone knows if the MK2 version will have WISA on board?
I can provide some features about the audio formats - in short terms: The new version is Apple LossLess compatible
Audio Formats BeoSound Essence MK1 MP3 32 -> 320kbit WMA, both VBR and CBR 20 -> 320kbit (No support for WMA Lossless) AAC (ISO and ADTS) -> 320kbit PCM (WAV) general + 88.2, 96, 176.4, 192kHz
Audio Formats BeoSound Essence MK2 MP3 WMA (No support for WMA Lossless) AAC (ISO and ADTS) PCM FLAC, 8-192 kHz, 16 or 24 bits, 2 channels ALAC, 8-192 kHz, 16 or 24 bits, 2 channels
The new essence comes without the Bluetooth control knob but an be installed with a new type (Beolink copy) wall eye for volume remote control, join and volume function.
L1NO: The new essence comes without the Bluetooth control knob but an be installed with a new type (Beolink copy) wall eye for volume remote control, join and volume function.
TWG: So you can use the NEW Beolink copy wall eye AND the "old" Bluetooth control wheel with the Essence?Any pictures of the new wall eye?
The ir-eye is the same as used with the NL/ML Converter.
It is a matter of software, how this 'eye' can be used - remote controlled as well as local controlled.
No details (that I know of) out yet.
I don't know if both can be used together - my guess is yes.
Was at the dealer right now - The MK2 Essence will have WISA on board.
carlito: Was at the dealer right now - The MK2 Essence will have WISA on board.
Finally, i always thought this was an Apple like move to hold back the first generation of the product that was made for wisa and get the second generation more features.
