Picture 2
Regards Graham
What are the physical dimensions of these, Graham?
I believe that the drivers are sold to a member from Norway. If he doesn't pay, i'll get back to you.
SamWise72: What are the physical dimensions of these, Graham?
From the main site:
Woofer: 25 cm Phase link unit:12.5 cm Mid-range unit: 2.5 cm Tweeter Dimensions W x H x D: 35 x 65 x 29 cm Weight 25 kg
Based on my two pairs, the above is correct, except the midrange dome is probably 5 cm and the tweeter is 2.5 cm.
EDIT
Actually, I doubt they weigh 25 kg each. Maybe 20 kg. Unless I'm stronger than I think, I just lifted them last night, and I don't think they weigh more than 50 pounds.
The drivers are now sold.
