M70 Picture 2
This post has 4 Replies | 0 Followers
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
joeyboygolf Posted: Sat, Feb 25 2012 3:09 PM
Picture 2
Regards Graham
SamWise72
Posts 53
SamWise72 replied on Tue, Mar 13 2012 8:01 PM
What are the physical dimensions of these, Graham?
joeyboygolf
Posts 4,188
I believe that the drivers are sold to a member from Norway. If he doesn't pay, i'll get back to you.
Regards Graham
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Wed, Mar 14 2012 5:38 PM
SamWise72:
From the main site:
Woofer: 25 cm
Phase link unit:12.5 cm
Mid-range unit: 2.5 cm
Tweeter
Dimensions W x H x D: 35 x 65 x 29 cm
Weight 25 kg
Based on my two pairs, the above is correct, except the midrange dome is probably 5 cm and the tweeter is 2.5 cm.
EDIT
Actually, I doubt they weigh 25 kg each.  Maybe 20 kg.  Unless I'm stronger than I think, I just lifted them last night, and I don't think they weigh more than 50 pounds.
joeyboygolf
Posts 4,188
The drivers are now sold.
Regards Graham
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
