hi.. yep im a newbie and i would appreciate some help please.
i have recently aqquired 2 sets of beovox 100 speakers. upon closer inspection the outside edge of the drivers has dissintegrated so im wondering if i can still buy replacement drivers ? and if not is it possible for someone to repair them ?
thanks
Two affirmatives for you! You can still get the drivers or you can get new rubber rings for the speakers. Either do it yourself - i am sure you will get some helpful hints on here, or buy the new units - your dealer can get these I believe.
Peter
Peter: Two affirmatives for you! You can still get the drivers or you can get new rubber rings for the speakers. Either do it yourself - i am sure you will get some helpful hints on here, or buy the new units - your dealer can get these I believe.
And there is a third option (depending on where you live) - to find someone who can change the rubber/foam rings for you. Here in Denmark there are several companies/persons that renew speaker sourrounds. And I know there are some in other countries too.
There are plenty of repair kits on ebay available, and it is not too difficult a job to refoam!
However, there are a number of methods which have been discussed a number of times on this site, its best having a look at some other threads to find out which one is best for you.
Ben
It's not too difficult. But some people manage to screw up the speakers badly anyway...
So - if you don't know what you're doing, then 'don't try this at home, kids'...
Check here
