Eclipse 65V1-32Beosound M5Essence MK2BLI
I don't know if this will help, or if it will get you to the right place, but here is how to get to the Customer Service Menu for the Beovision 11 (mind you, this is with a Beo4 / joystick)
- Press the MENU button on the remote control.
- Choose ‘Setup’ (on screen), and press the Centre button (remote control)
- Press RED button (remote control) and within 3 seconds press the Centre button (remote control)
- Choose ‘Settings’ (on screen), and press the Centre button (remote control)
Good Luck! (as always, be careful in these screens as they're not really meant to be accessed by the user). I used it to export the counters for the television to a USB Stick; Incidentally, here are those instructions:
The USB Stick should be formatted for DOS, and inserted in an available USB Slot.
Choose Reporting, export to USB stick.
Once done, at your computer, open the contents of the stick and the counters are located in a text file in the Calibration folder.
